| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
What is the simplest proposition for achieving 'fan on demand' with a thermistor?
I've got a handful of likely thermistors I can use. It's a noncritical application.. just turn on a 120vac muffin at about 100F and off again when it gets back to room temp. I looked about for kits/boards and came up pretty empty. Is there a really simple circuit posted somewhere? thanks |
#2 |
The simplest is to use one of those thermoswitches (whatever they are called). It is a switch in a metal case which is designed open (or close) at a certain temperature. You can mount it on the heatsink and use it to switch the fan on and off. Of course, it gives no regulation, there is just on or off.
#4 |
Banned
If you put a positive feedback resistor or preferably a pot from the output (1) of the opamp to the noninverting input (3),you will get some hysteresis, i.e. separate on and off points.
A signal diode (1N4148) may be adequate if the relay is small, in fact you might get away without it, but if the coil is big you might need a power Shottky. The deterioration in performance of the opamp due to reverse voltage when the coil is switched off may not manifest itself immediately... w |
#6 |
Instead of a thermistor that reacts to an already elevated temperature, you can monitor the load current and use it to trigger the fan. Since it takes a while for heat to build once the high current condition occurs, triggering the fan based on the current will reduce the maximum temperature rise.
I_F |
#7 |
Damn,
Yer gonna hate me for this after all the excellent suggestions. I may use some of them on something in the future. But this is really a simpler need. I've got a 1940s Ambassador record changer that is a bit of a treasure. All in one little lift-lid box with walnut veneer and little tube amp. Everything is completely original. It was hardly ever used. I appreciate it especially for spinning ancient 78s. There's just something heart warming about this music on this player on a pedestal table in the corner of the room sometimes. But it tends to rapidly overheat. The tubes and old motor with less than adequate ventilation just build up pretty fast. I don't want to do any real mods to this. But I'd like to put a little fan inside to boost movement out of the vents. The added fan noise and possible mechanical noise is not much concern at this level of fidelity. So I think I'll just put a five minute delay on break relay before the fan and call it good. That'll make the ol girl happy. |
#8 |
Why bother with a delay? Just run the fan whenever the power is on.
I_F |
#9 |
Mostly because I'm compelled in most cases to making my life difficult (as recent threads would attest).
But i'll give in. I'd like it to be cooling the motor (a quite bulky, heavily laminated job which stores tons of heat) between frequent cycles. There is no 'main' on/off switch. The knob which initiates the platter/changer cycle turns the motor and amp off each time a record or a stack finishes. I could add an on/off switch with a little indicator lamp. But that's a bit of a major modification. I'll just go ahead and run the fan when the motor is running. Originally I was hoping that a quick two or three element circuit with thermistor might be applicable to just adhering the thermistor to the motor laminations and it would be a neat little soulution. I have so many projects laying about right now waiting for exactly the right fix that I can't afford (for sanitys' sake) to add this to the pile! Thanks again for the suggestions. In fact christers' suggestion might be in the offing next time I order a box of parts from digikey. They have a little canned thermoswitch that operates at 40C for about six bucks. |
#10 |
How does one use the NC (Normaly Closed) ones?
I understand to use a normaly open one is easy... you just wire it all up and wait for the temperature to close the circuit... But I can't get my head around the Normaly Open ones... which are the common types in the temperature ranges usefull for an amplifier... |
| On demand vinyl pressing? | Francis_J_Kirk | Everything Else | 5 | 20th January 2009 12:17 PM |
| Enough demand to sell Silmic Caps to the DIY community? | Thomo | Parts | 4 | 23rd June 2007 06:26 PM |
| Survey: Is there a demand for high quality DIY chassis? | SRMcGee | Parts | 6 | 23rd September 2005 03:57 AM |
| Trouble with speaker protection circuit (Randy Slone's circuit) | whalefat | Solid State | 3 | 13th April 2005 10:13 AM |
| Page generated in 0.09951 seconds (83.12% PHP - 16.88% MySQL) with 10 queries |
