Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 30th June 2008, 05:18 PM   #1
Mooly's Avatar
Default HEXFET Complementary pairs. Recommendations please.
Probably should have loged in under an alias asking this one
HEXFET Complementary pairs !! Are any more "complementary" than others. I feel like dipping my toe in the water, and would appreciate any recommended combinations. I was thinking along the line of IRFP240 and IRFP9240 in the TO247AC insulated package.
I have a few ideas kicking around for a new amp build and want to see where it leads me.
Regards Karl
Old 30th June 2008, 07:24 PM   #2
irfp240/9140
regards Andrew T.
Old 1st July 2008, 06:42 AM   #3
Mooly's Avatar
Hi Andrew,
The 9140 ? that's a 100 volt device isn't it. Any reason why you paired this with the IRFP240 ? That could be a bit on the low side for what I had in mind. I should have said the rails would be in the -/+ 40 to 50 volt region.
What I was trying to get at is that with Bjt's I know some complementary pairs are much more - well complementary than others. I wondered if the same applied to HEXFET's and whether any particular pair stood out. And why ?
Thanks Karl
Old 1st July 2008, 08:39 AM   #4
240/9140 deliberately chosen by a few designers due to better matching of the more important parameters.
And, yes, limited to +-50Vdc supply.
regards Andrew T.
Old 1st July 2008, 10:03 AM   #5
Mooly's Avatar
Interesting --- Thanks. Just doing CPC and Rapid order now.
Quasi-complementary Hexfet monstrosity. Circlotron Solid State 38 28th December 2010 08:43 PM
complementary pairs tip29 tip30 Acoustat Solid State 3 4th April 2009 08:33 PM
Complementary JFET pairs in the UK? Mr Evil Parts 6 6th January 2007 10:32 PM
Complementary Power Mosfet Recommendations? thoriated Solid State 3 15th November 2003 07:26 AM
3rd generiation HEXFET vs. 5th generation HEXFET DarkOne Solid State 3 12th April 2002 07:51 PM
Page generated in 0.07149 seconds (73.64% PHP - 26.36% MySQL) with 10 queries
