Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
+/-15V power to a TI PGA2310.  15V regulators sufficient or do I need adjustable??
Old 27th June 2008, 07:11 PM   #1
nick_g_evans is offline nick_g_evans  United States
Default +/-15V power to a TI PGA2310. 15V regulators sufficient or do I need adjustable??
I'm building a circuit around a Texas Instruments PGA2310 digitally controlled volume controlled and I wanted to know if you guys think +15V and -15V fixed linear regulators are sufficient or if I should use + and - adjustable regulators.
Anybody have any thoughts? I'm wondering because I don't know if it matters if the +/-15V is off a little bit.
Thanks in advance...
TI Webpage: http://focus.ti.com/docs/prod/folder...t/pga2310.html
Datasheet: http://focus.ti.com/lit/ds/symlink/pga2310.pdf
Is cheap or expensive one hamburger ? - Upupa Epops
Old 27th June 2008, 07:36 PM   #2
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Technically speaking adjustable regulators usually have better noise specs than fixed regulators. Does it matter? That depends on the rest of your system and how picky you are. I'm fine with using fixed regs, but others avoid them like the plague.
And no, it doesn't matter if the positive and negative supplies don't match exactly as long as you don't exceed the devices voltage limit.
Old 16th July 2008, 11:50 AM   #3
jackinnj is offline jackinnj  United States
jackinnj's Avatar
With the adjustable regulators you can bypass the ADJ pin with a small electrolytic cap. It will be a lot quieter. Bob Pease from National Semi wrote an article on this in his book "Troubleshooting Analog Circuits".
+/-15V power to a TI PGA2310.  15V regulators sufficient or do I need adjustable??Hide this!Advertise here!
Adjustable power supply questions rendisha Parts 28 10th June 2013 09:57 AM
Sufficient power for the Fountek JP-2.0? mazeroth Multi-Way 3 20th April 2005 03:37 AM
Adjustable regulated power supply Ford_V6 Solid State 2 1st April 2003 05:03 PM
Bypass your adjustable regulators ADJ pin to ground to hear another veil drop... Dr.H Digital Source 1 1st August 2002 04:48 PM
DIY - Adjustable Power Supply Design vinay Pass Labs 7 20th March 2002 05:46 PM
Copyright ©1999-2017 diyAudio
