Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd June 2008, 09:33 AM   #1
Default 2SC3264 Replacement???
Is there a power transistor that has more power output than a 2SC3264, in a similar form factor?
the amp is the swr I am working on and am just wondering whats out there. Searching here hasnt come up with anything yet.
The amp has 8 of these in there, running them around 80 volts I believe.
Old 24th June 2008, 09:26 AM   #2
mos57 is offline mos57  Italy
Hi, you can substitute 2SC3264 with 2SC2921 OR 2SC2922. these transistor manifactured from same SANKEN are in my mind very similar. Yon can download the datasheet for your sure.
Francesco
Old 24th June 2008, 10:14 AM   #3
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Sanken is the only legit company that manufactures MT200 case ring-emitter devices and the 200W/230V 2SA1295/2SC3264 are the most powerfull they've got.
At +80V rail levels, substituting the originals by 160Vce 2SC2921 or 180Vce 2SC2922 is not really smart.
Even with knowledge about local mains surge values and powersupply regulation numbers it would be bad engineering.
Class A amplifier with 2SC3264 and 2SA1295 gili_flash Solid State 4 15th April 2010 03:06 PM
Replacement amp for A-Bus? Greg911 Class D 0 16th November 2008 02:33 PM
Sanken - 2SC3519A / 2SC3264 1965GTO Solid State 3 14th June 2008 04:57 AM
2sc3264's mudallica Parts 3 9th October 2006 07:26 PM
Sanken 2SC3264 in JLH? bremen nacht Solid State 3 23rd October 2004 07:59 AM
Page generated in 0.05430 seconds (77.46% PHP - 22.54% MySQL) with 10 queries
