Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st June 2008, 05:47 PM   #1
Default help in changing cap values for a disto stompbox
I hope this is the right forum to post, if not just tell me.
I'm building this:
and I just noticed I don't have any 0.1 uF cap. My guess is that both 0.1 uF caps are used to filter out DC voltage, so I plan to replace them with 1 uF ones. As I'm quite new at DIY audio electronics though, maybe I'm missing something.
So, what do you think? Is my guess correct ? Will the stronger cap values cause the universe to implode ?
Thanks in advance for your answers.
Old 22nd June 2008, 08:09 AM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
They also form a lowpass filter, I would not venture too far from the original values... just about any broken electronics (pre surface mount) should yield a few 100n caps... they might be marked 104, or 100n or 0.1u
Old 22nd June 2008, 02:44 PM   #3
Thanks for the answer. I have finally found a broken radio with a few cermacic caps labelled 104M, I guess they will do the trick.
About the lowpass filter I wasn't sure since there was no resistor with the cap (all the low and highpass filters I've seen in schematics have a resistor to ground). I'm guessing the resistance between base and emitter of Q1 plays the part of the resistor in the filter, ,am I right ?
Thanks again.
Old 22nd June 2008, 03:26 PM   #4
impsick is offline impsick  United States
impsick's Avatar
you might be able to get away with .082uf if you have that value.
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
My DIY stompbox Dr. Zoidberg Instruments and Amps 7 17th December 2010 08:17 PM
Stompbox problem lukeareid Instruments and Amps 0 16th December 2008 02:56 PM
changing (de)coupling cap values Klimon Tubes / Valves 14 25th April 2005 09:33 AM
Changing ZEN to Ret. of ZEN boq Pass Labs 1 28th May 2004 10:30 AM
Changing BF's for MJE's Bensen Solid State 2 27th May 2003 05:39 AM
Page generated in 0.07612 seconds (72.40% PHP - 27.60% MySQL) with 10 queries
