| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
My new UPS seems really incapable of supplying light loads. It would supply a 200W load for over 30 minutes but lightly loaded or not loaded at all it switches off in exactly 5 min. This seems like some type of a safety feature but for the life of me i can't see the purpose. Is this common? My other, very old UPS, certainly does not behave the same way. Any ideas if it is possible to modify this?
#2 |
There might be a logic to it: if it senses no load for a period of time, it decides it is not in use, and shuts down in order to save the batteries. I would imagine this kind of "feature" can be disabled via the console or dip switches (unless it is endorsed by Microsoft, off course). LV |
#3 |
Quite likely. A very annoying "feature" which makes it impossible to power up items with low consumption like ADSL modems/routers or laptops. I wonder if this is common with other modern UPSs. If it does indeed sense the output current, there is likely to be a sense resistor in series with the output, right? Sadly, no dip switches, pots or any possibility for adjustments.
| Are you (open) baffled yet? | ThorstenL | Multi-Way | 309 | 24th August 2010 03:03 PM |
| open baffled all over again | then_dude | Multi-Way | 58 | 5th April 2005 10:42 PM |
| Baffled By Choices | mopus | Multi-Way | 11 | 6th December 2004 03:46 PM |
| Passively baffled | jmiyake | Multi-Way | 0 | 3rd February 2003 11:26 PM |
| Totally baffled | Tomatito | Tubes / Valves | 26 | 14th November 2002 07:22 PM |
| Page generated in 0.07077 seconds (67.18% PHP - 32.82% MySQL) with 10 queries |
