Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 20th June 2008, 09:34 PM   #1
Stormrider's Avatar
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
Default BNC connections...
I just got my first oscope, a Fluke 97 scopemeter for free !!!
I got a standard probe with it but i need some test leads with alligator clips, but i don't want to pay 10$ each for a simple test lead. (That cheapo/diy spirit) Anyone know where i can get a few cheap or where i can find some BNC connectors that i can just solder wire to? The only BNC connectors i've found require expensive crimping tools and/or you have to use RG coaxial cable.
Thanks.
AJ
Old 20th June 2008, 09:55 PM   #2
Spiny is offline Spiny  United Kingdom
Spiny's Avatar
BNC are sized for 50 or 75 ohm - hence the RG cable attachment (Solder or crimp). You could use 50ohm BNC connectors a length of coax and split the coax out to clips - OK for LOW voltage DC.
There are some BNC to RCA (phono) adapters about, which would be easier to wire for temporary test leads. This is the type of thing - I sure they can be had cheaper
http://www.radioshack.com/sm-bnc-to-...b-support.html
Real scope leads (x1 x10 with trimmer) are needed for high voltage and ac measurements. There should be a calibration output on the scope for trimming the probe before measuring ac signals.
Old 22nd June 2008, 07:24 PM   #3
Apex Jr is offline Apex Jr  United States
Default PROBE
I have some male BNC Molded Male end to a dual
alligator clip probe made by Mueller in stock...
You can contact me at steve.apexjr@prodigy.net
Steve @ Apex Jr.
These are not listed on my website.
c3g connections garbage Tubes / Valves 8 16th October 2010 08:51 AM
What are XLR connections?? JuNA Pass Labs 30 24th November 2005 06:47 AM
HELP with connections Tony.ca Multi-Way 7 23rd May 2005 11:56 PM
no connections at all! Joel Tubes / Valves 0 31st January 2003 05:32 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
