Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th June 2008, 07:30 PM   #1
h_a is offline h_a  Europe
h_a's Avatar
Default Attach single wire to pcb?
Dear folks,
I have a strange problem!
For my pcb I'm searching for a way to connect a single cable/wire, however I want to avoid soldering it directly into a wire pad.
Well, terminal block you say - but these guys all start from 2 rows and I need only one row and further I'm limited on space (otherwise I would just parallel both rows).
A plug, maybe? Well, I would like to avoid crimping as well.
What do you use for that?
It's intended for smallish current (several amps) and should be as small as possible (about 10x5mm or less would be nice).
I know I don't have so many wishes free, but if one could easily buy it e.g. at Digikey?
Thank you! Have fun, Hannes
Old 18th June 2008, 08:19 PM   #2
Old Tek scopes and other test equipment used a closed end ferrel (sp?) that soldered to the end of the wire, and a little tubular socket that soldered into the board. About as simple as one can get, though I don't have a manufacturer or part number.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 18th June 2008, 08:48 PM   #3
Sonusthree's Avatar
Have you ever looked at dismantling a computer's Molex connector?
The metal pins can be removed form the plastic housing and they can then push- fit together. Of course, this would be a very compact solution but you'd need to heatshrink or find other ways to insulate the metal.
I'm assuming it's not too high voltage?
Martin
Old 19th June 2008, 07:23 AM   #4
h_a's Avatar
Thank you for your help!
I will see if I can find that at Digikey
Though I still hope somebody comes up with a simple and small connector? Has the world no space for space efficient single wire-to-board connectors?
So many people here do their own pcbs, what do you use?
Have fun, Hannes
Old 19th June 2008, 07:50 AM   #5
Nordic is offline Nordic  South Africa
Nordic's Avatar
Man, I would say go for a plain old PCB spade, easy to connect and disconnect.... I know it is not exactly what you wanted, but it seems like the smallest compromise...
Old 19th June 2008, 08:29 AM   #6
0.1inch pitch PCB pins.
Sockets are available in single upto 4way
regards Andrew T.
Old 19th June 2008, 10:15 AM   #7
h_a's Avatar
Thank you for your replies!
Indeed a pcb-spade was exactly what I thought! Pins would also be an option, however they always require a socket - for final assembly one could solder the wire onto the spade directly.
As it's intended for a ground connection I want a really good connection
All the best, Hannes
Old 19th June 2008, 10:48 AM   #8
Electrons are yellow and more is better!
peranders's Avatar
Spade contacts is nice, check picture below.
/Per-Anders (my first name) or P-A as my friends call me
Old 19th June 2008, 10:51 AM   #9
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
5mm.
Looks like Sponge Bob has killed another thread.
Old 20th June 2008, 11:50 AM   #10
h_a's Avatar
Ok spades it is then!
Thank you for your help! Have fun, Hannes
6S3B-V Wire-Ended Single-Triode tube Alastair E Tubes / Valves 3 11th June 2007 08:48 PM
4 channel of audio + single wire bilgekaan Everything Else 6 2nd March 2007 12:20 AM
Single wire interlink experiment? squadra Everything Else 17 24th February 2007 06:26 PM
Bi wiring/single wire distortion thread jneutron Parts 85 4th January 2006 11:20 PM
Page generated in 0.10633 seconds (81.42% PHP - 18.58% MySQL) with 11 queries
