Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th June 2008, 09:14 PM   #1
Default basic question on volume control
I am trying to build a little passive volume control unit, stereo in, stereo out, to be hooked up between my no-adjustable-volume CD-player and my headphones. But I am encountering a problem that the headphone impedance is much smaller than the pot resistance value and hence altering the volume.
I am using a 100k dual-gang audio taper radio shack pot. Taking the left channel for example, the two ends of the pot are connected to the left signal and the shield (ground). The center wiper is connected to the output. And the shield for the output is connected to the input shield. (as shown in the image, sorry for the crappy drawing)
Without headphone attached, everything looks fine. Half-way on the knob outputs a voltage roughly equal to 1/7 of the input voltage. BUT when a headphone with 40 ohm impedance is attached, the voltage across the headphone is almost zero since the 40ohm is connected now in parallel. I could only hear something when the knob is turned to almost full scale.
Is there any way to solve this problem? Thanks!
Old 14th June 2008, 09:21 PM   #2
theAnonymous1's Avatar
You need a headphone amp circuit or at least a buffer between the output of the pot and the headphones. You can't use a high impedance pot as a voltage divider for low impedance headphones.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 14th June 2008, 10:59 PM   #3
As mentioned, a headphone amp or buffer is by far the best solution but if you need to keep things simple you could just put a suitable variable resistor in series with the headphones
Old 15th June 2008, 01:52 AM   #4
Thanks for the advice. I guess that a buffer normally means an op-amp or some kind of circuitry that requires power? Am I right?
That's a good idea! Since the resistance of my portable headphones are roughly on the same scale.
Old 15th June 2008, 04:49 AM   #5
unclejed613's Avatar
you need to use a 50 ohm pot instead of 100k. a 100 ohm might work as well. once you get the 100k pot turned down to 90%, you have 1000 ohms in series with the headphones. that reduces your signal to (assuming 120 ohm headphones) 12% of it's original level (much lower if that's a log taper pot).
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Volume control for 41hz Amp6 Basic rca9449 Class D 10 14th June 2007 03:20 PM
Volume control question electric eric Parts 3 20th September 2005 02:58 AM
Volume control question for pre-amp, please help tschanrm Solid State 1 11th September 2005 12:50 PM
volume control question bonsai171 Solid State 4 25th January 2004 05:15 PM
Leach Amp Volume Control Question VictorG Solid State 2 17th November 2003 12:30 AM
Page generated in 0.08167 seconds (73.55% PHP - 26.45% MySQL) with 11 queries
