| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hey all, long time between posts.
I have a op-amp circuit im trying to analyse. I need to know the transfer function for it. I know the gain is -15. But id love to know how you get that value. Circuit is attached Cheers |
#2 |
It's a trick question, right? The 75k resistor goes back to the input, so its effect will be entirely dependent on the driving impedance of the source, which isn't shown. Driven from a low impedance source, it makes no contribution, so just analyze based on the gain of the two stages. If the impedance of the source is high, set that as a resistor to ground, then choose some arbitrary voltage at some point, say V3=1V, and just calculate around the circuit based on that. I'm too lazy, so would just put the circuit in LTSpice.
I used to be an audiophool like you but then I took an arrow to the knee. |
#3 |
The gain of the first stage is -Rf/Ri where Rf=18K and Ri=6K. The gain of the second stage is 1+Rf2/Ri2 where Rf2=8K and Ri2=2K. So yes, the overall gain is -15.
The 75K resistor doesn't do anything. The 10K resistor is irrelevant from a DC point of view. It may effect the ac performance of the circuit. |
#4 |
thanks for that, i was thinking the 75k was doin nothing too relevant. Bastards, this was a past exam question.
| Midrange Analysis | mbutzkies | Multi-Way | 4 | 25th May 2005 01:51 PM |
| cap analysis | yldouright | Parts | 3 | 7th January 2005 01:45 AM |
| Need help in circuit analysis | Fossil | Tubes / Valves | 6 | 23rd November 2004 07:13 AM |
| FFT Analysis | RobPhill33 | Everything Else | 22 | 19th March 2003 07:01 PM |
| Page generated in 0.09834 seconds (80.10% PHP - 19.90% MySQL) with 11 queries |
