Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th June 2008, 04:16 PM   #1
Default US Outlet NEMA double 'D' dimensions
I'm trying to prepare a CNC file for routing outlets, standard 5-15/20 duplexes. The Greenlee punch typically used is the 1.375" diameter X 1.125" across, but the material is too thick for a punch.
I've seen dimensions all over the place. Does anyone have a good set of values for the double 'D' that would acommodate the typical spec grade duplex?
TIA,
Paul
horn outlet direction ? ljk11 Subwoofers 2 24th June 2009 10:32 PM
M/S outlet (AC) bibster Parts 3 24th January 2008 09:47 AM
Trigger switched outlet robomatique Everything Else 9 13th December 2007 03:09 AM
NewarkInOne Ebay Outlet BrianDonegan Parts 0 28th May 2005 12:23 PM
Outlet to transformer switch for GC... mcelaj Chip Amps 2 16th December 2003 10:37 AM
Page generated in 0.05737 seconds (66.60% PHP - 33.40% MySQL) with 10 queries
