Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th June 2008, 10:49 PM   #1
rfarn is offline rfarn  United States
Default switching circuit
I'm looking for a simple switching circuit which, when power is supplied momentarily, an "electronic" switch would be closed.
I.E. An electronic version of a basic switch which is closed by momentarily applying power and stays closed after the power is removed. Idealy, there would be a second signal which would open the switch.
Old 11th June 2008, 10:55 PM   #2
darkfenriz's Avatar
A relay?
http://en.wikipedia.org/wiki/Relay
Old 11th June 2008, 11:13 PM   #3
Kind of. A relay only closes when there is power supplied. Looking for one that will "change state" when power is supplied, and keep that state (opened/closed) when the power is removed. Also looking for a strictly electronic, not electro-mechanical solution.
Old 11th June 2008, 11:57 PM   #4
Hello rfarn, what kind of voltage and current capacity are you looking for? If it is low you could probably use a regular momentary contact switch with a flip-flop. The flip-flop, per its name will switch output states when it gets an input pulse. Usually they work off of logic voltages, 5vdc (TTL), 3vdc (LVTTL).
Peace,
Dave
Old 14th June 2008, 05:26 AM   #5
That might work. Just looking for a simple A/B switch to change sources on a sterio.
Old 14th June 2008, 01:42 PM   #6
Hello rfarn, the flip-flop would work for providing a latching control signal, but you would still need relays to actually switch the audio signal. In the application you are suggesting, reed relays would work.
Peace,
Dave
Old 14th June 2008, 02:03 PM   #7
there are a few latching switch circuits in the Forum.
regards Andrew T.
AC to DC circuit switching using function generator, need help jegandren Power Supplies 11 6th August 2008 09:36 AM
Rail Switching vs. "predictive" rail switching rtarbell Solid State 5 4th March 2007 10:26 PM
Trouble with speaker protection circuit (Randy Slone's circuit) whalefat Solid State 3 13th April 2005 10:13 AM
Relay switching circuit please jnewbold Solid State 10 3rd March 2005 06:39 AM
Switching circuit help needed trustalbini Tubes / Valves 15 26th July 2003 08:23 PM
Page generated in 0.07979 seconds (73.76% PHP - 26.24% MySQL) with 10 queries
