| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi to all, this is my first post and its a help me sorry.
I am going to re cap my moth power amps and i have found a shop that has most parts in stock, my problem is which caps to use. The caps fitted to the amps are samhwa 4700uf 63v and there is 2 others which are 470mFD 16v and 470uf 63v. My question is what is uf and mFD i have been told that 2 of the caps are feedback caps and have to be right i need to know what the parts are before i send a order off as i dont want to blow up the amps. Hope this makes sense |
#2 |
mFD is often used instead of µF. It's a source of confusion as mF is in fact milli(F) and uF or µ(F) is micro(F).
So, both caps are most likely 470µF. A picture would give more certainty. Here's a nice page on capacitors: http://www.uoguelph.ca/~antoon/gadgets/caps/caps.html /Hugo |
#3 |
Thanks for that,its like school again!!!!!!!! lots of reading.
Thanks. |
#4 |
Another interesting thread (tough more specific about known bad caps and their replacement on voltage filtering circuits) are there:
http://capsmod.net/forum/viewthread....extra=page%3D1
"It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire ...just keep folding, just keep folding... |
#5 |
Thanks for the replys.
I have changed the caps and the feedback caps,only to still have a small problem!!!!!. When i first switch the amps on i get a hum/buzz sound that last for a few seconds and the amps go quite and i then can use them. The noise is only there when first switched on. I thought the noise was a cap problem thats why i changed them and also there were 20yrs old. So i am at a loss now as to were to look on the amp for the problem. Any help please. The amps are Moth 100 watt mono amps. |
#6 |
I would start replacing all the caps, becuase they are likely to be dried out already. 20 years can last only quality ones... VERY quality ones.
#7 |
Hi thanks for the reply, i have changed all the caps i could see and even the 2 feedback caps,but i still get a noise when first switched on.
Like a buzzing arking then all goes quite????? I have att a pic dont know if it would be of help. Pic to big will have to sort it and post it later. |
#8 |
Is there anyone who can change the size of a file if i send it to them so i can put it on the page.
| Best PS capacitor | RFENG | Parts | 3 | 19th January 2008 02:44 PM |
| what capacitor is this? | abiedoodles | Parts | 10 | 12th December 2007 07:11 PM |
| Capacitor Help | MorePower7701 | Solid State | 8 | 25th July 2007 06:41 PM |
| Capacitor esl | dhole | Pass Labs | 1 | 23rd April 2005 02:18 PM |
| Capacitor or not? | future | Parts | 2 | 24th June 2003 11:10 PM |
| Page generated in 0.09409 seconds (77.45% PHP - 22.55% MySQL) with 10 queries |
