| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I would like to motorize my volume control using a motor, pulleys and belt. I would also like a clue. Where do I start?
I just briefly looked at rentron.com but how can I use those circuits to control a motor? I just want to be able to make the motor turn in either direction. Nothing fancier than that. Would something like this be a start? http://www.rentron.com/project03.htm |
#2 |
Bent audio has a solution for a seiden switch. I believe they will also have one for the DACT switch.
What is your volume control (Pot, stepped attenuator, etc...) Could use a small stepper, a DC motor, etc...
doing my part to Keep Austin Wierd. |
#3 |
I have a pot now but will be going to a stepped attenuator. Stepper, DC, etc was what I was envisioning.
But my only electronic skills are basically soldering and putting batteries in the right way. |
#4 |
It would be a whole lot easier to do if you started with a motorized pot. www.brigarelectronics.com has an inexpensive one by Alps. Then all you'd need is to have the relays on that kit apply dc voltage to the motor, and the reverse polarity turns it the other direction.
#5 |
This is what the Bent audio passive remote looks like with a Seiden switch and S&B silver transformers. Maybe this will work for you.
My "cult-like" following is accepting applications. |
#6 |
The Bent implementation is exactly what I was thinking. I didn't see a price for the upgrade on their web page but if their other pricing is any indication, it will probably cost more than the preamp I want to put it in.
Using a system like this gives me the freedom to use pretty much any attenuator I want. Any ideas on how I could build one myself? |
#7 |
The remote kit option is $225.00.
#8 |
I'm working on a similar project. Here's what I've found so far.
Motor pots: http://www.alltronics.com/resistors.htm MOTORIZED SLIDE POT 10K ohm pot 4" Travel 6-12VDC Fast belt drive. 5¾"L x 11/16"W x 1"D. 22P011 $4.95 each MCM# 2110544001 10KOHM VR MOTORIZED $29.65 http://www.mpja.com/productview.asp?product=14552+PT 14552 PT Price:$ 0.99 http://www.goldmine-elec.com/pdf/241page69.pdf G9962 $3.49 ea. http://www.allelectronics.com/cgi-bi...?item=MPOT-10K CAT# MPOT-10K Your Price: $4.00 each IR Stuff: http://www.rentron.com/remote_control/IR-D14.htm Item: 14-Bit, IR-D14 Infrared Decoder IC Part Number: IR-D14 Price: $8.00 ea [Quantity 1-4] Item: Vishay Telefunken 40KHz IR Detector Module Price: $4.00 ea Part Number: TSOP1140 http://www.kitsrus.com/pdf/k92.pdf K92 IR Remote Control and Decoder IC GP1U52X Infrared Receiver/Modulator - sold by Radio Shack at cat. No. 276-0137 HTH, Emory
no sig |
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 07:20 PM |
| Remote volume control for existing remote? | theAnonymous1 | Parts | 7 | 6th August 2007 08:22 AM |
| Alternate surround repair method | mashaffer | Multi-Way | 2 | 12th September 2006 02:04 AM |
| Remote volume - existing remote | Stuey | Chip Amps | 16 | 25th August 2006 11:44 PM |
| Page generated in 0.14792 seconds (59.31% PHP - 40.69% MySQL) with 11 queries |
