| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#2 |
Banned
Excellent Peufeu,
You never fail to amaze! What will you come up with next - a multichannel ethernet DAC? |
#3 | |
No time to look at it in great detail, but from what I have seen it looks very clean and well thought out... |
#4 |
If you Google the Seattle Robotics Society and "reflow oven" (or something like that), you'll find a very nice web page on reflowing SMT with a toaster oven. Works great; I have one at work that I bought at WalMart
bel |
#5 |
Such ingenuity with an everyday object is a sign of genius!
#6 |
Yeah I had seen the page on Seattle Robotics... actually I looked at lots of DIY reflow ovens before building this one
It's not hard, mostly mechanical stuff, and being safe with the high voltage... the temperature controller I used is very simple to use. |
#7 |
I tried my 1st reflow soldering today using an oven similar to the Elektor reflow smd oven. The oven is fine; the problem I have is with applying the solder. I'm using a syringe with solder paste, and I find it hard to apply a small amount of paste to the board. The plunger of the syringe has to be pressed quite hard because the paste is so heavy, and then when something comes out, it is too much! How do you guys do that, any tips? Jan Didden
/Another new issue: Linear Audio Volume 3! |
#8 |
This beautiful and informative article, thank you very much. Use this page to your friend told you. I am constantly followed. To receive more information about this topic the following internet sites can follow.
Jan, have you tried warming the syringe? I think you're seeing the effects of the thixotropy of the paste, and there's not much to be done about that.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#9 |
I once made a screw like thingie, to attach to the syringe. This made application much easier to control, and the use of a very thin needle possible, as pressure no longer was an issue to build up.
Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#10 | |
I was also looking at what are called 'component stencils' which are stencils for individual components like a 40 pin QFP quad pack or a SOIC. You can get them for $35 each in stainless steel or from another outfit A 4*4 inch stencil to your design for $25, and you apply the past with a queegee I think it is called (basically an old screwdriver jd
| How good are Mutant subs | goldyrathore | Subwoofers | 2 | 17th December 2008 12:10 PM |
| suprising smd reflow fix | peace brainerd | Parts | 2 | 5th June 2008 07:32 PM |
| heatsink, the mutant | bigpanda | Parts | 4 | 6th July 2006 03:33 PM |
| Gryphon Simphony stand mutant | marijan | Everything Else | 10 | 11th February 2003 01:33 PM |
| Aleph 2 Toaster | macka | Pass Labs | 10 | 9th November 2002 05:32 AM |
| Page generated in 0.10071 seconds (86.96% PHP - 13.04% MySQL) with 11 queries |
