Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th March 2003, 07:30 PM   #21
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Meta,
The heatsink mounts on the back of the equipment case. The regulator is mounted on the case side of the heatsink. Behind the sink there is a hole where the regulator sits. The electronics (apart form the heatsink vanes is invisible).
If you want to take the other route, that's OK with me, but I'm willing to help if you want to continue. The heatsink on offer is free
Your call...
Old 17th March 2003, 08:02 PM   #22
Hey John...
Nice1 mate, i'll def continue on it - there's no particular rush atm, as the instrument itself isnt finished yet...
I can picture the heatsink better now - soz, i just got in right pickle there ;p
so, how do we go about gettin that sink sent then? how heavy is it? I'll of course pay for any delivery charges...
Thanks again...
Old 17th March 2003, 10:39 PM   #23
dhaen's Avatar
Meta,
e-mail me your address.
It's light, postage is no problem.
Old 19th March 2003, 03:34 PM   #24
Hey John...
Sink arrived - nananice1!
Okay, so the hole which looks like it attaches to the regualtor seems a tad small (M2?) is it okay if i drill a bigger one so i can get an M3 screw n nut in there? Should i glue the back of the regualtor to the sink too? Then i guess i cut a rectangular hole out the back of the case so the regulator pops through and i'm then able to get at the pins...soundabout right?
Cheers
Dan
Old 19th March 2003, 03:42 PM   #25
dhaen's Avatar
Dan,
There is an M3 stud that you can use to invisibly mount the regulator.
The 2mm hole was for an LED to poke through, but it's small enough to ignore.
You can of course enlarge the hole and use bolt-through if you wish.
What?
The regulator should be mounted onto the heatsink with the insulating bush and thermal (silicon) washer.
Yes
Old 19th March 2003, 03:48 PM   #26
Cool, i getcha now - if i dont blow myself and the house up beforehand - i'll post some pics of the operation to make sure it all looks good prolly next week sumtime...
Thanks again, that offer of the midibox16 pcb is still valid btw...
Old 19th March 2003, 03:56 PM   #27
dhaen's Avatar
Default No MIDI....I'm English....
Good stuff.
BTW, I've probably got a spare English dictionary....
Only joking Bet u spnd al ur time txting....
807 E-Linear Fuling Tubes / Valves 51 5th April 2011 01:27 AM
linear pot sakis Solid State 4 9th August 2008 01:34 PM
Linear PS help ashley_kitty Power Supplies 2 16th May 2007 12:00 AM
Need help with linear PS tonyptony Power Supplies 33 14th April 2006 09:37 AM
Page generated in 0.08742 seconds (75.99% PHP - 24.01% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
