Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 27th May 2008, 02:59 AM   #1
Default Test/Measure power amps
Hi guys, i want to know what tools i need to purchase to draw graphics about power amps, to write specs. i want to know at least
Power Output into 8 and 4 ohms.
Frequency Response
THD
Slew Rate
Rise time
Damping Factor
Signal to noise ratio
Input Impedance
Input Sensitivity
Thanks in advance, hope that is possible to find
Old 27th May 2008, 03:48 AM   #2
You could buy a scope, distortion analyzer, and the usual signal generators and stuff usually found on a test bench, or you could go to the Audio Precision site and buy their box. In terms of credibility, the AP is the way to go since its so much an industry standard these days.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 27th May 2008, 04:22 AM   #3
Thanks too much, will see the Audio Precision products, but looks expensive
How do I measure amps? doug20 Solid State 4 27th July 2009 02:57 AM
So how do you measure power amplifier PSRR then? GK Solid State 22 21st December 2008 02:09 AM
How to measure amp power output hernanstafe Parts 2 16th February 2007 01:27 AM
SMPS for diy audio amps and multi-channel diy amps (and their power supplies) tlparker Solid State 18 31st August 2006 10:39 AM
How to measure Distrotion in power Amp ?? papanohn Solid State 5 19th August 2004 03:02 PM
Page generated in 0.06648 seconds (69.55% PHP - 30.45% MySQL) with 10 queries
