| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I wish to purchase 8 UCC 68uF 63V (actual voltage is only 15V) capacitors to recap my Mark Levinson 38S. I saw them some months ago in Mouser but I cannot find them now. Is there any other places that I can find them?
Thank you |
#2 |
I do mean the type looks like aluminium cans, not those with plastic wraps.
#3 |
re
#4 |
doh, remove the plastic wrap, the can lives inside...
#5 |
Changing my cloths will not make me a real king.
I am talking about the UCC 678D capacitors that the new UCC are LXY series only. Is there anywhere I can purchase 678D now? 68uF 63V |
#6 |
Sorry man, misunderstanding... I think those are Sprague... tried google?
#7 |
I seen on Digi-key plenty of these Chemi-cons, however:
http://search.digikey.com/scripts/Dk...ords=Chemi-con ...none of the "678D" series I never ever heard before about. If you can stick with 68uF 63V LXY, then there ya go: http://search.digikey.com/scripts/Dk...me=565-1857-ND http://search.digikey.com/scripts/Dk...me=565-1858-ND Are those used for voltage filering or audio transfer/decoupling? For voltage filtering I would go into lower ESR ones, like Samxon GD/GC or Rubycon MBZ/MCZ ones. Panny FC/FM are also great choice and I would use 16V ones, if the highest spike on then is 15V (measure the spike with scope only, forget DMM) ... For audio I would recommend true good audio caps, like at least Elna RFS or Rubycon Black Gate C series. A 100uF 25V Elna RFS is available there: http://search.digikey.com/scripts/Dk...me=604-1055-ND ...however it is a big suxxka, d12.5 ... will THAT fit in?
"It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire ...just keep folding, just keep folding... |
#8 |
Thank you for the information. However, I am looking forward to recap the amp with the original caps, if possible.
#9 |
I understand, but... what if they are nonexisting?
And what reasons to have - since they are very likely used just for voltage filtering - to stick with possibly fake caps that died already? I could be wrong, but Chemi-con never produced a 678D type as far, as I know and I'm into the capacitor replacement bussinness for quite some time...
#10 |
NCC LXZ, KY or KZE should be comparable to or better than the original LXY in all the relevant specs.
| what is the difference between silver mica capacitors and ceramic capacitors ?? | prorms | Solid State | 1 | 6th May 2008 12:38 PM |
| Continental Capacitors' "Type-A" oil-filled capacitors? | radical | Parts | 0 | 21st October 2004 08:39 PM |
| Oil capacitors | Praudio | Swap Meet | 3 | 7th October 2003 03:00 AM |
| capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors | costiss | Parts | 11 | 30th January 2003 09:32 PM |
| differences between computer grade capacitors and small can capacitors | LBHajdu | Pass Labs | 0 | 22nd February 2002 01:29 AM |
| Page generated in 0.09285 seconds (79.14% PHP - 20.86% MySQL) with 10 queries |
