| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Is it possible to determine the crossover frequency of an existing 2-way speaker crossover with limited info?
I believe it is a 2nd order with two caps and two coils. From other examples it looks like they are in a parallel configuration. The capacitor values are 10uF and 4.7uF respectively. There are no listed values on the coils (wound around a plastic spool with small air hole in the middle). Can they be measured on the circuit board with a volt/ohm meter? |
#2 |
Hi Focal7C,
Measuring the voltage vs frequency response across each driver gives you the overall voltage response of the passive filter and its load. You need a sine generator and your multimeter needs to be linear up to 20 kHz (beware your ears) There are some free software on the net which can help you, you can even measure your coils. |
| Replace crossover in existing box | ccdoggy | Multi-Way | 56 | 15th January 2008 08:27 AM |
| How to determine crossover frequency? | maurycy | Multi-Way | 2 | 7th January 2006 03:29 PM |
| Is there a formula to determine the frequency at which... | 454Casull | Multi-Way | 3 | 12th September 2004 10:57 PM |
| how do manufacturers determine frequency response? | pkgum | Multi-Way | 19 | 27th December 2001 05:08 PM |
| Page generated in 0.06412 seconds (66.56% PHP - 33.44% MySQL) with 10 queries |
