Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 25th May 2008, 06:31 PM   #1
Ralph is offline Ralph  Netherlands
Ralph's Avatar
Default Trouble with 64-step relay attenuator (RelVol1)
I am building an all new pre amplifier combining the P06a pre amp from Rod Elliott and the 100k RelVol1 kit from Dantimax. It's a 64 step relay attenuator with 6 relays.
The problem is that on some steps the sound gets way louder than it should be. The next step is back to normal levels. It happens every 8th step from 0-63 (7, 15, 23, 31, 39 etc). This is when the first 3 relays (1, 2, 4) are always switched in.
What did I check:
- I checked all resistor values, they are as specified (no mixup).
- Also I checked if the values are correct for a 64-step 1.5dB per step setup. Seems ok (see worksheet 3)
- Resolderd every joint.
- All relays switch on/off when they should be.
Is there some other thing I can check? I measured resistance per step and pre amp output (ref 1V in) per step, please take a look at the Excel spreadsheet (the yellow steps are the problem ones). Any help is much appreciated!
http://www.jonkers.net/audio/relvol1.xls
Ralph
Old 26th May 2008, 05:54 PM   #2
gootee is offline gootee  United States
Can you post a schematic, or a link to the schematic?
Old 26th May 2008, 06:48 PM   #3
Ralph's Avatar
This is a link to the schematic. http://electronics.dantimax.dk/SiDow...elVol1_sch.gif
As you can see, R1..R24 are the resistors that determine the steps. I have verified that they are of the correct values and that I soldered them correctly.
R27/28 are the loading resistors. For a 100K load I use 11K1 resistors for each.
After doing some more testing Today, I determined that if I remove the loading resistors all together, the steps are working fine! There is no more jumping in level. However, from steps 10 or so down, the level increases a bit and is very thin sounding. So obviously it's still not entirely correct. But I'm guessing that the loading resistors are the cause of the problem.
Ralph
Old 27th May 2008, 07:43 AM   #4
Ralph's Avatar
Problem fixed I think. I was using incorrect loading resistors (11K2). This also gives me the problems in the simulation. I'll replace them with 100K ones tonight and I should be fine.
Yet another relay attenuator jwb Solid State 34 21st July 2010 07:17 AM
24 Step Attenuator poynton Parts 1 9th January 2008 07:26 AM
23 step attenuator tryonziess Chip Amps 2 21st May 2007 12:33 PM
Alps step attenuator kmtang Tubes / Valves 5 30th May 2005 11:51 AM
speaker protection relay trouble lordy Solid State 21 23rd October 2004 04:08 PM
Page generated in 0.07169 seconds (76.66% PHP - 23.34% MySQL) with 10 queries
