Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 25th May 2008, 09:03 PM   #1
Default Musical Fidelity B1 amp transformer problem.
I wonder if anyone can help me. My old Musical Fidelity B1 integrated amp has stopped working.
I don't know much about electronics but a poke about with my multimeter tells me that there is power going into the toroidal transformer but nothing coming out so I'm assuming it is that which has failed.
I know nothing about transformers so am stuck as far as replacing it in that I haven't a clue which one to buy. If I give the details of the original would someone please be able to tell me the right type and rating of replacement to get. It is made by ILP, has two wires in and three out, and the label says Type 30054, serial no. 23169.
Any advice would be much appreciated!
Ian
Old 26th May 2008, 06:49 PM   #2
gootee is offline gootee  United States
gootee's Avatar
Depending in the power supply circuit, you might also need to suspect some other components. I usually tend to try to blame any electrolytic capacitors, first, then rectifiers, then transformers. Is anything getting hot?
With power off and disconnected (and caps discharged 'manually'), you can measure the resistances across the various power supply components, looking for shorts and opens. Maybe a diode or rectifier bridge has become shorted.
Old 26th May 2008, 09:00 PM   #3
Many thanks for the advice Tom. Amp not powering up so don't know if anything was getting hot. I can detect power going into the transformer but nothing the other side of it. Don't know how to discharge caps so have done no testing of other components.
Ian
musical fidelity b200 transformer sakis Solid State 4 4th July 2009 10:04 PM
Musical Fidelity problem garysnooker Solid State 5 29th October 2008 10:50 AM
Musical Fidelity F16 problem/Schematic Smiffy Solid State 8 10th December 2006 05:39 PM
Musical Fidelity E60 Transformer??? delory Digital Source 0 25th July 2005 04:22 PM
Page generated in 0.07352 seconds (71.85% PHP - 28.15% MySQL) with 10 queries
