Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th May 2008, 01:20 PM   #1
Default Need 4 conductor cable with connectors & receptacles
I'm building a Pearl preamp with a separate power supply and I need a way to get the power from one enclosure to the other. This requires 4 separate wires, pins, etc. I'm having a hard time finding what I need. My usual vendors (Digikey, Allied, etc) overwhelm me with options that are all discrete pieces - connector shells, contacts, receptacle shells, more contacts, cables... There doesn't seem to be a way to buy anything in a kit form (I'd be happy with a connector kit, a receptacle kit and the cable), nor even cross-references for the parts.
I'd like the assembly to have some sort of locking mechanism, to not be too large - say less that 1 inch in diameter for the connector, and the cable will be about 8 feet long.
Suggestions?
Thanks!
Old 24th May 2008, 02:33 PM   #2
amc184 is offline amc184  New Zealand
amc184's Avatar
I don't know any that come as a kit, but here's what I use:
- 5 core trailer cable (any hardware store)
- 5 way 'mike' line connector and chassis plug (any electronics store)
Click the image to open in full size. Click the image to open in full size.
They are cheap, easy to get, the connectors lock well, and they are easy to solder.
This cable is five way, you can leave the fifth core out, or use it as a chassis ground.
Old 24th May 2008, 02:40 PM   #3
check out canare 4s11 cable. You can terminate it with whatever connectors you feel like.
Paul
Old 25th May 2008, 08:51 AM   #4
I've been using a lot CDROM audio cables lately.
They're compact, interlocking, cheap, easy to come by, and fairly
high quality. Most are shielded too.
You're already familiar with the cable I'm sure, so here's the
connector. (Careful ordering cables, some are only three wire)
Digikey --- WM4802-ND - CONN HEADER 4POS .100 VERT GOLD
If those don't fit the bill, maybe these are more to your liking.
All Electronics -- CON-234 4-PIN-CONNECTOR-W/HEADER
Ooooops! I missed the part about being 8 feet long! Sorry.
Writing is good exercize for the texticles!
Old 25th May 2008, 12:11 PM   #5
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
The mic plug shown above also has a 4-pin version.
4-pin XLRs would be my choice.
5-pin version of both allows you to use separate shield-
or, 4-pin for + Gnd - , and shield
The PCB interconnects , CD-rom plugs etc are not suitable for this purpose
Old 25th May 2008, 12:50 PM   #6
After spending way too long searching, I managed to find suitable parts from Digikey and some Canare 4S6 (the 4S11 is too thick to fit in the plugs) from another vendor.
Thanks for the suggestions!
Re-terminating a XLR cable with RCA connectors fatwok Parts 9 14th February 2009 11:50 PM
GB Silver Connectors & Cable. jleaman Group Buys 14 11th May 2007 11:39 AM
Page generated in 0.09023 seconds (75.50% PHP - 24.50% MySQL) with 10 queries
