| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
i have an easy ? for some of you .
ok i have a Peltier im running with 2 12v pc fans. the Peltier is rated 45.6w 12v (15.2v max) 3amp im running the Peltier and 2 fans on a 7.5v 3a ac/dc adapter i have a 12v 2a ac/dc dapter laying around ? what is better more volts or more amp? the Peltier is cooler with both fans hooked up compair to just one even if the second one isnt blowing on the Peltier heatsink cooling the hot side so im guessing its a v vs a thing |
#2 |
Can you draw a schematic. it sounds like you have the fans ran in series with the peltier, limmiting the current.
#3 |
using ohms law
your peltier has a resistance of 5.06 ohms 45.6 / 15.2 = 3 amps 15.2 / 3 = 5.06 ohms so at 15.2 volts you are going to need 3 amps just for the peltier. for 12 volts: 12 / 5.06 = 2.37 amps 12 * 2.37 = 28.44 watts for 7 volts: 7 / 5.06 = 1.383 amps 7 * 1.383 = 9.683 watts So With 7 volts you are only going to draw 1.3 amps at most and you are only going to use about 1/5 of what your peliter is capable of. With 12 volts you are going to use 2.37 amps and you are going to use about 1/2 of what it is capable of. and at 15.2 volts you are going to use 3 amps. |
#4 |
A Peltier device is a diode. It is a nonlinear resistance, so the resistance will vary depending on the current run through it. If you're trying to match the manufacturer's ratings for the part you'll need to match the specified current (just like an LED).
You want to use a current sourcing power supply, not a regulated voltage supply. I_F |
| 845 Low voltage SE AMP | =maximum= | Tubes / Valves | 8 | 19th July 2007 10:56 AM |
| Should I use high voltage value zeners or multiple lower voltage zeners in series? | jarthel | Parts | 7 | 30th May 2006 04:56 PM |
| Rail Voltage to Capacitor Voltage | Mermprin | Parts | 6 | 20th September 2004 03:56 PM |
| secondary voltage vs. primary voltage | Stocker | Parts | 5 | 11th March 2004 07:41 PM |
| Rail voltage compared to transformer voltage | SteveG | Solid State | 4 | 22nd July 2002 11:50 PM |
| Page generated in 0.07638 seconds (75.23% PHP - 24.77% MySQL) with 10 queries |
