Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th May 2008, 07:44 PM   #1
Default Spring Return to Center Rotary Switch
Hello,
I am looking for a source of a rotary spring loaded 'return to center' switch. I want to replace the traditonal volume potentiometer in a preamp that I am building with a digital switch. The appearance will remain the same as if I had used a traditonal pot.
It works this way ...
The user rotates the 'spring return to center' knob left a few degrees to close a switch. The switch closure is monitored by a PIC that steps down the gain. Similarly rotating the knob to the right closes another switch and the PIC increases the gain. I've got the PIC code worked out. What I am looking for is a source of switches. The switches needs to have a shaft that accepts standard knobs. Anybody know of a source??
Best Regards,
Carl Huff
Old 17th May 2008, 09:52 PM   #2
Steve Eddy's Avatar
Mouser part number 690-E3G0603N-2.
It has more poles than you'll need and it costs $42.30, but it will do what you're looking for.
This has come up a couple times before and that's the only readily available switch of that type that anyone's so far been able to find.
se
Old 18th May 2008, 03:47 AM   #3
Boy that seems like a lot of money for what it is.
But thanks for the quick reply!
Best Regards,
Carl Huff
Old 18th May 2008, 05:15 AM   #4
Chartal is offline Chartal  Canada
Hi
I don't think the Electroswitch is good for low voltage and current of is application, because of its open design (not seal). But I can be wrong.
Here is 2 threads about rotary switch for volume control.
Rotary encoder instead of buttons
Two position rotatory switch with spring return wanted
Old 18th May 2008, 04:21 PM   #5
Thanks for the pointers!
I saw these threads when I searched the forums. I don't like the Rockwell industrial switches because, well ... they feel and look industrial! They are more appropriate to a fork truck than a preamp. I am looking for a switch with a quarter inch shaft that I can put a traditional aluminum knob on.
Surely there is something out there that we've all missed.
Best Regards,
Carl Huff
Old 27th June 2008, 11:42 AM   #6
Foehn is offline Foehn  New Zealand
Default Rotary Switches
Can anyone enlighten me on how dual deck rotary switches work? Might seem a daft question, but then I'm not very familiar with them. This one is made by Elcon and appears to be a dual deck. It has 30 pins on each deck.
Old 4th July 2008, 09:05 AM   #7
Default Silence is deafening
I take it that is also a no! Gee! You Audio people are sure helpful!
Two position rotatory switch with spring return wanted DocLorren Parts 11 7th April 2008 07:31 PM
Rotary Switch Redux ... udtman Parts 3 25th March 2008 12:15 AM
rotary switch woodturner-fran Parts 5 9th February 2008 09:04 AM
Rotary on/off switch kestrel200 Parts 2 23rd April 2006 09:23 PM
Rotary switch Freddie Solid State 1 30th August 2001 07:55 PM
Page generated in 0.08926 seconds (77.33% PHP - 22.67% MySQL) with 10 queries
