| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
well, I got shafted on this one ...
![]() I've designed myself in a corner and need a specific part that I cannot seem to find state-side. Without further ado, the part in question is: - 5K pot, linear (not too picky 1k-5k might work too) - Bushing needs to fit in a 8mm hole (less is fine) - Needs a bushing that is long enough to accommodate a 0.25" panel yeah, that's about it. As crap-tastic of a pot as you can find will work. I'd rather not talk about recessing the panel or anything else to modify the panel.. just looking for a part, that seems to be unobtanium. I'm hoping that metric loving countries might have better luck? |
#2 |
Most pots are 9mm and up are'nt they?
Why not tap that 8mm hole to accept one of the 9mm pots screwed into the thread... ?alternatively use angle stock or U-bar to attach the pot inside and an extended shaft. |
#3 | |
#4 |
how about?
http://www.radioshack.com/product/in...entPage=family - 5K linear - its 6mm, so less than 8mm as per your spec. - can be mounted in a 5/16" hole, so if possible could you drill out the 1/4" hole you specified to 5/16" and you're good to go. |
#5 |
and update... I found a pot that fits. Vishay/Spectrol 248-series, or mouser 594-248-1502....
now, my knob won't fit I tried wrapping it with paper, and that didn't work. Here's a pic:it's says its for a 6mm hole and has a single set screw. The new pot shaft is 0.125" diameter and rather short.... (this is another problem with the above knob, as the set screw is right at the end and if I raise the knob a bit so it doesn't scrape the panel, then it doesn't fit so well). So, any pics of custom knobs to give me an idea of some options? There's a place in town that does custom knobs for reasonable prices, so all I need is a good idea, and a picture |
#6 |
See If you can't find a metal guy that can drill and tap a second screw hole on that lip...
#7 | |
-Marc |
#8 |
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net spammer trap: http://www1284177414881.v-dc.net/ |
#9 |
#10 |
believe it or not, I find a local outfit that will do it for $18. It will be 1.5" in diameter, 1" deep and support the 0.125" shaft. Made from stainless with a position indicator. Here's their website:
http://www.armadilloguitar.com/ |
| Thanks all from helping me fix a Krell CD-DSP ! | krellie | Digital Source | 0 | 5th January 2009 12:30 AM |
| Hello all, hows about helping a newbie | justblair | Chip Amps | 31 | 21st February 2007 03:36 PM |
| I would like to publically thank RJM for his efforts in helping us | frank2395 | Analogue Source | 2 | 17th June 2005 02:29 PM |
| helping a first time builder | Swanic | Parts | 2 | 20th October 2004 09:36 AM |
| Helping out in the bass department | joeling39 | Multi-Way | 6 | 4th December 2003 03:42 PM |
| Page generated in 0.10060 seconds (86.49% PHP - 13.51% MySQL) with 10 queries |
