Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 15th May 2008, 11:16 AM   #1
Default Need help to identify potentiometer in amc 1030
Hi guys, i need help to evaluate the code part from amc cvt1030as service manual, i would like to change the potentiometer, which i learn would improve the sound.
written on the part list:
29-4165-2 pot, volume RK16122BOR76-20KAx2-EK
or might be RK1612280R76-20KAx2-EK
the writting is blurry, its either "Bo" or "80" or "B0" or "8o"
does the above value bring any information?
the potentiometer for stereo and has balance, by balance i mean that we can set left and right volume differently. the pot has 6 legs
whats the value of the pot? 20k ohm?
whats the equivalent upgrade from TKD pot that is the same with above.
thanks in advance
erwin
Old 15th May 2008, 12:59 PM   #2
oshifis is offline oshifis  Hungary
Does it look like this?
http://www.fwd.com.tw/english/Produc...ster/RK161.htm
Old 15th May 2008, 03:16 PM   #3
yes with 6 pin but no rectangular thing at the back. its does look like normal pot. nothing fancy. does the code above bring any sense? thx
Old 15th May 2008, 05:04 PM   #4
gain is offline gain  United States
gain's Avatar
Default Re: Need help to identify potentiometer in amc 1030
do you have an ohmmeter? if so the value of the pot is very easy to measure. the six pins sounds like its a typical dual ganged stereo pot.
Old 15th May 2008, 05:40 PM   #5
measure all the 3 pairs? how to detemined? all three show same value?
Old 15th May 2008, 07:03 PM   #6
Minion is offline Minion  Canada
The codes seem to indicate a dual ganged 20K Log pot...
Old 16th May 2008, 02:31 AM   #7
Thanks guys for all the reply, what happen if we put different value pot ? will it affect the system? system impedent or something?
Old 16th May 2008, 12:20 PM   #8
gain's Avatar
while facing the back of the pot, measure the resistance between the leftmost terminal and the rightmost terminal of the three. do not connect to the center terminal (wiper). this resistance reading will be (approx, within 5-10 percent) the value of the pot. imo, don't rely on package markings when you don't have to, as they can be misleading.
yes, installing the wrong value could cause problems.
Old 16th May 2008, 12:45 PM   #9
Great. Another question, is pot sensitive to heat? As my soldering skill is not v good
Old 16th May 2008, 04:17 PM   #10
Yes Pots are sensitive to heat ,Just like all Components heat is the enemy.... Pots aren"t as sensitive as some transistors and other passive components but I have ruined a couple pots by useing too much heat....Actually the ruined pots still worked but were really scratchy and would intermitantly short out....
Just make sure your Iron is Hot and tinned and your wire is tinned before soldering as the tinned lead will solder better than a bare copper wire....
Cheers
Marantz 1030 urgent help needed! bbarone Solid State 11 22nd April 2009 12:10 PM
Akai AA-1030 schematic? TomWaits Solid State 2 9th November 2007 08:38 AM
Need help for Eico 1030 regulated power supply pchw Tubes / Valves 3 7th September 2007 05:27 PM
Looking for Eico 1030 manual/schematic pchw Tubes / Valves 0 1st March 2007 04:47 AM
Max Pentivent 1030 as bass guitar speaker labougie Subwoofers 5 26th March 2005 04:26 PM
Page generated in 0.10978 seconds (80.60% PHP - 19.40% MySQL) with 10 queries
