| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Is there a simple way to make a 15m/sec sound delay circut. this is for a car.
#2 |
bump
#3 |
delay turning on the ignition for 0.015Seconds.
regards Andrew T. |
#4 |
The simplest delay generator is the PT2399 - regrettably the shortest delay it can do is around 30ms. The NJU9702 does 0.5 to 32ms in 0.5ms steps, but you need a small micro to load the timing register (the littlest pic would do it). Other than that...a stretch limo with a 17 foot long cab would give you 15ms end to end.
M |
#5 |
"The simplest delay generator is the PT2399 - regrettably the shortest delay it can do is around 30ms. The NJU9702 does 0.5 to 32ms in 0.5ms steps, but you need a small micro to load the timing register (the littlest pic would do it). Other than that...a stretch limo with a 17 foot long cab would give you 15ms end to end."
This is for a stretch RSX. The difference between my front speakers and rear is 3.002 ft. Where can I purchase a NJU9702 and what s a small pic? |
#6 | |
M |
#7 |
Thanks. I will need to investigate a little and then get back with the results or more questions.
Thanks again. |
| UcD - correlation between phase lead network and propagation delay | Cro maniac | Class D | 2 | 12th April 2008 06:35 AM |
| Simple spdif delay? | TNT | Digital Source | 1 | 24th January 2007 09:26 PM |
| 'Simple network lowers f3' | PeteMcK | Multi-Way | 0 | 10th December 2005 03:40 AM |
| Simple turn-on delay | elizard | Solid State | 1 | 31st March 2004 05:45 PM |
| need for simple all pass digital delay | mr_ro_co | Digital Source | 6 | 20th January 2004 10:04 PM |
| Page generated in 0.09380 seconds (77.98% PHP - 22.02% MySQL) with 10 queries |
