Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th May 2008, 10:53 AM   #1
Filburt is offline Filburt  United States
Default Capacitors in a filter application
I'm thinking of changing around the capacitors in the LPF on an Assemblage DAC-2.6. It came, stock, with WIMA MKP2 caps (or whatever the 5mm ones are). I just recently tried Panasonic ECQ-P 630V, but those ended up being too laid back or something; there was a slight sense of veil that was off-putting.
I'm thinking of using the Multicap (Polystyrene) that Parts Connection originally offered as the upgrade since I'm curious about that. I've also seen people mention Vitamin Q PIO caps as good but I have zero experience with that stuff and it's difficult to find good information on how well those would work for this sort of application. I'm not looking to spend tons of money since eventually I'll be installing a (discrete) current steering i/v in place of the THS4031 I'm currently using (AD825 is as LPF/Buffer). However, I also think I should be realistic and realise that I may just not get time for it for a while, so I figure it may be worth getting good performance out of what I'm using right now.
So, any suggestions would be helpful. Cap values are 0.015uF, 0.022uF, and 3900pF (e.g. 0.0039uF).
Old 14th May 2008, 11:22 AM   #2
3n9F, 15nF and 22nF are all available in either polypropylene or polystyrene. PS will be bulky and expensive.
PP in commercial types can be bought in these sizes very cheaply.
Before spending large amounts of money on a few exotic caps, try buying a selection of cheap metallised film polypropylene from various manufacturers and to various voltage ratings and styles.
You may well find the solution is much cheaper than you expect.
Have a look at the caps thread for the classD amp. It has a lot of cheap ideas in there as well as some more expensive ones.
regards Andrew T.
Old 16th May 2008, 05:28 AM   #3
Thanks for the help, Andrew.
I decided to bite the bullet a few days ago and just buy the RTX. They fit, barely. I had to sort of finagle it to get the 0.022uF in, but it does fit for the most part.
The performance is outstanding; I'm seriously impressed. Much better than the ECQ-P Panasonics and the WIMA MKP2s. I pretty much ended up with exactly what I was trying to achieve, so I'm quite happy
Matching capacitors for filter redrabbit Parts 4 3rd July 2008 10:14 AM
5R4WGY/A/B , input filter capacitors riccardo Tubes / Valves 12 26th July 2005 09:08 PM
Does more tubes = more filter capacitors? edsmith Tubes / Valves 3 20th June 2004 10:16 PM
Paralleling or Cascading Power Supply Filter capacitors question KevinLee Solid State 4 29th April 2003 12:13 PM
Page generated in 0.07436 seconds (81.30% PHP - 18.70% MySQL) with 10 queries
