| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I just found out that my meter does not have enough resolution to measure mVac . But it can measure a mVdc with higher resolution. Should i use a bridge rectifier and convert ac volt to dc volt and then measure the dc volt ? Or do i need to spend money on another DMM ?
#2 |
Easiest way of getting really acurate AC volts is with a true-RMS meter like the Fluke 8920A or the HP 3403 (or other HP instruments). But dealing with the situation at hand. Remarkably, the Fluke 8920A is sometimes offered for around $20 on EBay.
If you are going to go the way of rectifying the a.c. use a "precision rectifier" -- basically a pair of opamps which will swing rail to rail -- then you have to filter the resulting signal with a low pass filter -- almost to the level of DC. http://www.tech-diy.com/precision_rectifier.gif if you're ambitious and want truely "true" RMS measurements you should consider the Linear Tech LTC1966 or LTC1968. Linear sells a development board for $50. ![]() The LTC1966 is more acurate, the LTC1968 has greater bandwidth:
#3 |
The purpose of this is to measure voltage for t/s parameters. I don't want it to be super accurate. I just need something acceptable.
So there should be no problem using a bridge rectifier made of small diodes right ? Or would these give me some other problem ? |
#4 |
Your going to lose the junction potential of the diodes -- for a 1N4148 its about 600mV -- and you've got to draw some current across them to get it to work. further, you have to integrate the output -- i.e. use a capacitor -- which loads the circuit differently at each unique frequency.
This circuit appeared in the Modern Circuits Ref Manual |
#5 |
Yep you will at least have to find some germanium diodes... like is used in analog VU meters...
#6 |
Or just buy a Fluke 7XXX series which will be probably good enough for you
Edit..I use a calibrated 73III |
#7 |
I might as well skip the t/s parameter testing. So troublesome.
| Multimeter | fauxpas | Tubes / Valves | 38 | 24th December 2007 12:28 AM |
| power transformers 220 volts to 110 volts | garydmd | Chip Amps | 3 | 7th April 2007 02:52 PM |
| WTB: Multimeter | bjackson | Swap Meet | 0 | 4th October 2005 12:10 PM |
| Gainclone is on 120 volts will it be fine at 220 volts? | Jimmy154 | Chip Amps | 7 | 29th June 2005 12:10 AM |
| Page generated in 0.08993 seconds (73.41% PHP - 26.59% MySQL) with 11 queries |
