Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
TO-3 transistor - best practice?
Old 7th May 2008, 07:37 PM   #1
Nordic is offline Nordic  South Africa
Nordic's Avatar
Default TO-3 transistor - best practice?
What is the best way to connect to the transistor case?
2 legs are obvious... but not the case... maybe one of those wire crimps with a hole in, on top, underneath the screw's top?
I'd like to use an insulated sink.
Old 7th May 2008, 09:09 PM   #2
pilli is offline pilli  France
This is how you usually see them:
The top is free from cables, and insulated with the mica.
The screws are not insulated from the case.
Underneath, the screws are insulated from the heatsink with a plastic washer, quite the same as those used on TO-220 packages.
One of the screws has a "tabbed-washer" (don't know the name of those things...) to which you can solder the wire, and then a spring-washer to ensure tension, then the nut.
_
Old 7th May 2008, 09:10 PM   #3
...Sorry if the pictures are a "quick and dirty" job, I couldn't find a neat "exploded view" anywhere quick.
Anyway the thick green line represents the heatsink, the thin green line represents the mica; hardware is mounted in the shown sequence.
Edit: You can buy the entire kit (mica + all washers) for 25 cents.
pilli
_
Old 7th May 2008, 09:25 PM   #4
...a neat exploded view can be found on this site (towards the end of the page).
I am not sure I am allowed to paste here the copied picture, so just the link. And it is in French.
(The part labelled "canon" is a "nylon bush", all the rest is metal.)
http://pagesperso-orange.fr/mgiaco/e...htm#Assemblage
(For those who understand French, that page also has an extensive analysis of heatsinking.)
_
Old 7th May 2008, 09:56 PM   #5
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Solder a wire to it.(e.g. MF)
Old 8th May 2008, 12:31 PM   #6
Nordic's Avatar
Sweet, thanks, then it seems I have every thing I need...
TO-3 transistor - best practice?Hide this!Advertise here!
Practice run at a DIY turntable dnewma04 Analogue Source 30 15th January 2011 04:06 AM
Practice Amplifier thespeakerguy Instruments and Amps 21 24th August 2008 07:11 PM
Sound Practices: is it out of practice? grataku Everything Else 0 24th November 2003 08:51 PM
Bass practice amp FBLEAGH Instruments and Amps 4 19th November 2002 03:57 AM
