| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi guys, can someone please point me what i need to purchase/build to measure amplifiers? i want to exctract the specs of some amplifiers-
Thanks in advance. |
#2 |
Dummy loads, voltmeter, ammeter, oscilloscope, signal generator.
If you want to do distortion measurements you'll need either a distortion analyzer or a DSO (digital storage oscilloscope) with FFT/DFT capability. That should be about all you need for basic measurements. The only things you can really DIY here would be the signal generator and dummy loads. For a signal generator you can either build a circuit, or simply use your computer's sound card. As for the dummy loads, essentially you just need to rig up some resistors together to achieve the correct impedance and power handling capability. Someone mentioned using kettle heating elements, that's the cheapest solution for high-power dummy loads. Just refrain from winding a bunch of wire into a coil and using that as a load, since that will have high inductance and might skew the results, or even cause instability. |
#3 |
Can you give me more specs? for example i have a few Digital OSC TDS220, and TDS460A, Multimeter.
i dont have signal generator (just the PC but i want to purchase a good signal generator) |
| How to measure drivers for xo design at low Fc? | tcpip | Multi-Way | 21 | 9th July 2006 04:21 PM |
| What equipment do i need to measure my DIY speakers? | boogs | Subwoofers | 3 | 28th October 2005 12:47 PM |
| need a help with software to design amplifiers.... | Dj BASS AMP | Solid State | 1 | 6th September 2004 08:11 PM |
| speaker design and evaluation equipment - what are my basic needs? | k98luka | Multi-Way | 7 | 30th January 2004 01:23 PM |
| Page generated in 0.07952 seconds (69.88% PHP - 30.12% MySQL) with 10 queries |
