weight & treble amp - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd May 2008, 10:22 PM   #1
foxman is offline foxman  United Kingdom
Send a message via MSN to foxman
Smile weight & treble amp
some one posted a circuit diagram showing how to build a weight & treble Pre-amp. I am looking to build one myself and wanted a correct diagram, and list of parts with correct values, and also help in finding the parts i will need, I was wondering if anybody can help i live in the uk thanks!
Old 5th May 2008, 02:34 AM   #2
Default weight & treble pre amp
I have an original Weight and Treble pre-amp designed for reggea/soul/dub reggea and drum & bass, the company who made and designed this amp as stopped making them some time ago 20years, thsi was desined for the disco and sound system circuit, I have look at it and it semms relativley easy as the components are big and the very simply in its layout. I have thought off making one for my car as i am currently running two amps but lack the individal bass/mids and treble with master volume control which allows you to control the ratio of bass/mids & treble to both amps or use the kill switch by killing the mids and just having the bass and treble going, i have some pictures but can take more detial close ups x10 . can anybody help me with this project and share this technology thanks.
Old 5th May 2008, 02:34 AM   #3
Default about wieght & treble car amp
I believe a Parametric amp is the same as the weight & treble and one of these could be upgraded by using different Caps and resistors for the frequency bands. The Para EQ's in my opinion can be brought then upgraded to give the enhance sound effect, gain amp moduls and others are availble as ready made blocks that can easily be modified to fit the project.
Old 31st March 2014, 09:01 PM   #4
hi do you still want to build the tuac if so i can hel
Old 6th April 2014, 03:47 PM   #5
hi i have built sevaral preamps for sound systems . i am looking for the tuac weight and tops pre amp but cannot find the circuit diagram. if you want to buildit i can help.
Old 6th April 2014, 03:57 PM   #6
hi has anybody got the tuac weight and tops preamp circuit diagram?
Old 25th April 2014, 09:41 PM   #7
Default tuac
i have a weight and treble pre amp and it dont sound so sweet.
so would like to see any schematics to check mine hasnt been bodged
cheers
Old 26th April 2014, 12:18 PM   #8
Default tuac weight and treble
GREETINGS dub organiza
i would very much like to see any schematics you have. when you say your amp dont sound sweet. i am surprised these amps were very well constucted. i will check it out for you no problem. may be simple depending what the problem is.
i am designing a amp based around the weight and treble it will be 3 way and have a 9 band para ma metric eq, bass and treble filters and return and send inputs. do you have any electronic experience?
PEACE !!!!!!
Old 26th April 2014, 08:47 PM   #9
greeting dub orginiza
what do you mean when you say it dose not sound sweet?
peace!!!!
Old 30th June 2014, 02:42 PM   #10
Hi I also have just bought a TUAC Weight & Treble pre-amp if anyone has a circuit dia or any pics of the internals would be most helpful.... I also have a TUAC VA11C1 pre-amp which I need the connections for,so ditto for that too
Aluminium & O-Rings - My Record Weight taniknight Analogue Source 6 5th June 2011 09:09 PM
Bass&Treble settings on pre-amp? Wild Willy Analogue Source 3 29th April 2011 12:15 AM
tone control (bass & treble) Salinas Chip Amps 2 13th July 2005 02:43 PM
A weight vs. linear weight gary f Multi-Way 1 2nd April 2004 02:23 PM
Max weight on a passive 12" Peerless XLS?? Jonnravn Multi-Way 34 3rd September 2003 04:09 PM
Copyright 1999-2017 diyAudio
