Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd May 2008, 03:23 PM   #1
Default newbie capacitor question
can i use normal 1uf 400v capacitor to replace a 1uf 280v x 2 suppression cap? this suppression cap is located on output and input stage of yaqin tube buffer
can i use 5uf 400v(film cap) parallel with 10uf 250v (elektrolitic cap) to replace one 15uf 250v electrolitic cap?
Old 2nd May 2008, 03:56 PM   #2
forget to mention that the suppression caps are connected with the output and input rca of the yaqin tube buffer.
thx in adv
Old 2nd May 2008, 04:40 PM   #3
Minion is offline Minion  Canada
You can use those caps as long as the are the same or higher Voltage of the originals...So a 400V capacitor can replace a 280v one ,But not the other way arround unless you know the Maximum Voltage will not be reached....
Old 2nd May 2008, 04:45 PM   #4
even normal cap to replace the suppression cap? arent suppression cap do suppression stuff while the normal cap doesnt? thanks
Old 2nd May 2008, 04:57 PM   #5
Yes...Suppresion caps are double wound and have no air gaps and such and are used to supress RF noise and other hash but In a tube buffer I believe you might not get any real extra benefit ...
All I can say is try it with the caps you have and if you don"t like the sound fork over the extra money for the proper Supression caps...
I"m sure someone with more knowlege of the curcuit you are working on and info on suppression caps will chime in...
Old 5th May 2008, 02:31 PM   #6
nt
Old 5th May 2008, 04:17 PM   #7
is the X2 cap 280Vac?
This is rated for use across 220/240Vac mains live to neutral and is self healing if subjected to a high voltage spike (is it tested to 1500Vdc?).
A 400Vdc cap is not an equivalent.
regards Andrew T.
Newbie: Resistor and Capacitor Types for Aikido Headphone Amplifier DrDeville Headphone Systems 7 9th December 2006 04:10 PM
Very Newbie Question - Is this a electrolytic capacitor? zBuff Parts 1 11th July 2006 02:05 AM
Newbie capacitor question The Nephilim Multi-Way 13 16th June 2005 09:57 PM
newbie post, but hopefully not a newbie question wiredcur Solid State 3 24th August 2002 10:49 PM
Newbie: Aleph2 Capacitor Question acliao Pass Labs 3 5th June 2002 02:31 AM
Page generated in 0.08916 seconds (74.65% PHP - 25.35% MySQL) with 10 queries
