Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 26th April 2008, 02:00 PM   #1
MikeHunt79's Avatar
Default Speakon screws?
I'm mounting some Speakons in my tapped horn, but the screw holes are really small...
Where can I get screws small enough for Speakon sockets?
Old 26th April 2008, 02:29 PM   #2
Did it Himself
richie00boy's Avatar
They are M3 bolts or #6 wood screws. Shouldn't be hard to get hold of from any hardware shop or DIY chain.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 26th April 2008, 11:16 PM   #3
MikeHunt79's Avatar
I tried some M3 bolts I had handy, but they were too big. They are proper Neutrik speakon socket, I would be able to post what type they are but the farnell website is down.
Does anyone sell m2.5 or m2 nuts and bolts?
Old 26th April 2008, 11:38 PM   #4
AKN is online now AKN  Sweden
Enjoy good sound
AKN's Avatar
What speakons, link, pic?
I've mounted many Neutrik speakons and recessed M3 fits nicely.
Edit:
Spec sheet tells that the mounting holes are 3.2mm, ie allows M3 bolts.
/ Anders
Old 27th April 2008, 12:06 AM   #5
MikeHunt79's Avatar
Edit:
I've just found my receipt and I ordered "NL4 MDH 2:SOCKET 4WAY HORIZ", and I found a datasheet also, it looks like to hole needs a 2mm bolt:
Do M2 bolts actually exist?
Old 27th April 2008, 12:12 AM   #6
Enjoy good sound
AKN's Avatar
The speakons you have are supposed to be mounted behind a thin panel and to be mounted with self winding "wood screws" into the speakons. They are made for pcb mount btw.
/ Anders
Old 27th April 2008, 12:32 AM   #7
MikeHunt79's Avatar
I did originally intend for these to go in an amp, hence PCB mount, but they'll actually work fine in my horn with the right screws... I've found some M2 bolts on e-bay but they aren't long enough, so I may just have to order some more sockets which are wood (not metal)...
Old 27th April 2008, 12:38 AM   #8
Enjoy good sound
AKN's Avatar
Ok, drill the 2mm holes up to 3mm.
/ Anders
Old 27th April 2008, 01:00 AM   #9
MikeHunt79's Avatar
I feel to stupid! I blame the hangover... Tomorrow I'll break out the 3mm drill bit and this thing will be finished!
Old 7th May 2008, 09:08 PM   #10
Default screwed!
can send you some screws and nuts....countersunk heads and prob about 10 mm long...how many do you need? just standard size i use....aha i noticed the diagram, horrible nl2 pcb mount yuck....yeah they are usually fitted with self tapping type screws....yuck! offer stands of the proper jobby's if you dont have anything suitable, prob m2.5 thread (but dont quote me!
speakon to RCA help joka22 Solid State 11 15th July 2007 04:08 AM
Speakon Na4lj wotsascott Parts 3 7th July 2006 04:42 AM
SpeakON vs five way binding post ashok Parts 1 3rd March 2006 03:23 PM
Speakon Connectors Mr Teal Parts 1 25th January 2005 08:04 AM
Page generated in 0.11487 seconds (76.87% PHP - 23.13% MySQL) with 10 queries
