| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Folks:
Is 32 gauge wire suitable for line level signals in a preamplifier? I have a 25' spool of very high quality 32 AWG silver wire and was thinking of using it in an Aleph P 1.7 project. I'd like to use this stuff in something good, but only if it is right for the job. Thank you, Scott |
#2 |
diyAudio Moderator Emeritus
I don't see why it wouldn't be ok to use unless you have some long runs of it since it is pretty small. I'd be more worried about physically breaking the wire.
Brian |
#3 |
32AWG is good for roughly 90mA in transformer use. Probably twice that as wiring in open air. As long as you don't cook it, I say go for it.
Allen Wright had good results with thin wire. Cheers! |
#4 |
sweet for connecting signal ground...
| litz inductor wire for speaker wire. | fazman | Everything Else | 126 | 20th June 2011 02:48 PM |
| 22 AWG silver plated solid copper wire for speaker wire? | G | Full Range | 21 | 15th February 2009 09:32 PM |
| magnet wire (not sure of the term) used as chassis wire? | jarthel | Parts | 8 | 27th September 2006 09:50 PM |
| How to wire a Ixos Gamma 7 bi-wire cable | mangalchacha | Multi-Way | 1 | 13th April 2005 02:58 PM |
| Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? | Layberinthius | Tubes / Valves | 0 | 11th March 2004 08:49 PM |
| Page generated in 0.06017 seconds (82.61% PHP - 17.39% MySQL) with 10 queries |
