Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd April 2008, 10:29 PM   #1
Bernhard's Avatar
Default AWG wire
The AWG is it with insulation or the size of the bare wire ?
Assuming it is the bare wire, how can I know the outer diameter of the insulation ?
Old 23rd April 2008, 10:39 PM   #2
AWG
American wire guage.
This is the size of the bare conductor.
Micrometer?
7/10
Old 26th April 2008, 08:42 AM   #3
AWG is usually applied to a single core solid circular wire.
When describing a multi stand cable, does AWG represent the equivalent copper content in the cross section of the cable or cord?
regards Andrew T.
Old 29th April 2008, 11:07 AM   #4
sandstorm33's Avatar
AWG applies to any type wire. It refers to dimensional characteristics and does not deal with copper content. Aluminum conductors are classified in the same AWG's. AWG also is used by THE NATIONAL ELECTRIC CODE in rating ampacity of a given conductor.
Old 29th April 2008, 12:40 PM   #5
that's rather different from European/UK practice where the sqmm (square millimetres) is referring to the copper cross sectional area, irrespective of whether it is solid single core or multistrand.
regards Andrew T.
Old 12th May 2008, 08:39 PM   #6
gain is offline gain  United States
gain's Avatar
never measured the cross sectional area myself, but i do know that solid core conductors of a given AWG have the same ampacity rating as a multistrand conductor of the same AWG, given they are both made from the same conductive material. since in physics the function of resistance in a wire is dependent on its cross sectional area, length, and conductivity, all other things being equal this would seem to indicate that wires of the same AWG have the same copper cross sectional area, regardless of number of strands.
Old 12th May 2008, 09:35 PM   #7
which is it?
regards Andrew T.
Old 12th May 2008, 09:40 PM   #8
Although the AWG tables are normally for a single, solid, round conductor, there are many cases in which AWG is applied to wires with multiple strands. When a stranded wire needs to be converted to an AWG equivalent size, the cross-sectional area of the conductor which determines its current-carrying capacity and electrical resistance (not its diameter), is taken as the determining factor. This permits stranded wire to have a slightly different diameter than solid wire having the same AWG.
From Wikipedia.
7/10
Old 12th May 2008, 09:44 PM   #9
AKN is online now AKN  Sweden
Enjoy good sound
AKN's Avatar
Link
/ Anders
Old 12th May 2008, 09:48 PM   #10
gareth is offline gareth  Wales
gareth's Avatar
Stranded cables generally have a higher Current rating than Solid core conductors. If you cut open large armoured cable for instance, each of the cores consists of many single cores to give a large stranded conductor.
The cross sectional area can ge ascertained by using :-
pi * diameter˛ ÷ 4
Cross sectional areas upto 600mm˛ are not uncommon.
Gareth
litz inductor wire for speaker wire. fazman Everything Else 126 20th June 2011 02:48 PM
22 AWG silver plated solid copper wire for speaker wire? G Full Range 21 15th February 2009 09:32 PM
magnet wire (not sure of the term) used as chassis wire? jarthel Parts 8 27th September 2006 09:50 PM
How to wire a Ixos Gamma 7 bi-wire cable mangalchacha Multi-Way 1 13th April 2005 02:58 PM
Page generated in 0.10799 seconds (78.55% PHP - 21.45% MySQL) with 10 queries
