| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm embarking on a ZenV5 style power supply and I'm toying with the idea of winding my own inductors.
What would be the likely outcome of using 16ga.THHN instead of enameled magnet wire? thank you, 7/10 |
#2 |
Likely outcomes: you will need a slight bit more wire than with enamel coated wire; the wire will not retain a bend as easily thus being more difficult to wind into a tight coil.
That's about it. No significant detriment to the determined. Regards, David |
#3 |
Thank you David !
I have a thousand or so feet of the stuff and rarely use it anymore. I'm stoked to see at least a couple hundred feet go to good use 7/10 |
#4 |
I on the other coast have a thousand feet or so of unused 16AWG magnet wire! Maybe I too can find a slightly less than typical application for my wire.
#5 |
diyAudio Moderator Emeritus
Speaker wire, interconnect wire, anything you could use normal wire for basically
Brian |
| Copper coil inductor vs. round core inductor | tomchaoda | Pass Labs | 7 | 21st September 2011 04:42 AM |
| Home wound inductors. | Big_Bill | Multi-Way | 10 | 29th July 2009 09:16 PM |
| An SE 813 OPT?? SP. Wound??who zat? | Richard Ellis | Tubes / Valves | 1 | 10th May 2009 09:11 PM |
| dvc has me all wound up | Dave R | Subwoofers | 3 | 13th July 2008 04:11 AM |
| uneven wound 50w OT 2 ideas...? | dud_wity | Tubes / Valves | 13 | 29th March 2004 12:54 PM |
| Page generated in 0.08895 seconds (74.13% PHP - 25.87% MySQL) with 10 queries |
