Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd April 2008, 05:10 PM   #1
MervinG is offline MervinG  United Kingdom
Default Audio pot working the wrong way round?
I have a lineout signal from a mixer unit that I would like to hook up to a 10K log pot in order to control the volume, before it goes off to a headset.
I have wired:
- signal +ve from mixer to pin 3 (right-most) of pot
- signal ground to pin 1 (left-most), and headset -ve
- output wiper from pot to headset +ve
When I turn the pot, the volume range varies nicely. The problem is that full anti-clockwise on the pot is "max volume" and full clockwise is "min volume", ie. it is reversed. In all other respects the variation in volume throughout the range is perfect.
I must be missing something simple here. Please can someone explain to me how to wire it such that full anticlockwise gives low volume and full clockwise gives max volume?
I've tried swapping the various connections around, but no joy. In particular, if I swap the connections to pins 1 and 3 of the pot, I get the correct direction in change of volume, but for the majority of the pot travel from zero to around 80% CW there is no output. Between 80% and 100% CW the output is max volume - ie. there is a surge of volume and not a uniform change like there was when the direction was reversed.
Appreciate any ideas...
Mervin
Old 23rd April 2008, 05:38 PM   #2
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Read this.
http://sound.westhost.com/pots.htm
Looking from the front of the pot,
Left - pin 1 ground
Centre - pin 2 output
Right - pin 3 input
Hindenberg audio recorded at wrong speed Richard Ellis Everything Else 8 1st June 2009 12:06 PM
Cambridge Audio A3i stopped working... Franne500 Solid State 1 1st May 2008 03:46 PM
Car audio amp, LOUD buzz. what is wrong? silentblackhat Chip Amps 2 12th April 2006 06:49 AM
Working on Digital Audio with C67/C55 kami10001 Digital Source 2 5th December 2004 10:50 AM
US bought car audio FM not working in India sunchand Car Audio 7 20th May 2004 06:55 PM
Page generated in 0.07412 seconds (68.11% PHP - 31.89% MySQL) with 10 queries
