Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th April 2008, 05:10 PM   #1
DreadPirate's Avatar
Default Audio pot for thickwalled cases
I've found a wooden case for my project, but I can't seem to find a pot that has a long enough threaded section. The wall thickness of my case is .33 and it looks like most pots are .25. Are there any pots out there that have a longer threaded lenght for wider cases? Same problem for the RCA jacks, but I can probably get away with countersking them as they are going in the rear.
Old 18th April 2008, 05:15 PM   #2
Mooly's Avatar
Could you set the pot back in the case on a bracket or on the PCB and extend the shaft ( extenders should be readily available ). This would stop you being tied to a non standard part as well.
Regards Karl
Old 18th April 2008, 06:30 PM   #3
Geek's Avatar
Checkout replacement pots for guitar amps, from AES. Some of those have very long bushings.
Cheers!
Old 18th April 2008, 07:36 PM   #4
Minion is offline Minion  Canada
What I have done when useing a Wodden case that had a Thick front pannel was to counter sink the Back of the Pannel with a 1in Wood bit which would leave a indent the right size for the pot to sit in and would make the pannel thinner at that spot so the shaft of the pot fits through.....
Just a thought!!
Old 19th April 2008, 05:41 AM   #5
I_Forgot's Avatar
Mount the pot on a bracket and extend the shaft using a piece of 1/4 metal tubing from you local hardware store.
See pix here: http://mark.rehorst.com/LM3886_amp/p...up_2_small.jpg
and here:
http://mark.rehorst.com/LM3886_amp/Amp_interior.jpg
Couple the metal tube to the pot shaft using plastic tubing and tie wraps.
I_F
Old 19th April 2008, 08:03 PM   #6
dsavitsk's Avatar
http://www.oselectronics.com/ose_p100.htm
http://www.ecpaudio.com
Old 22nd April 2008, 01:47 PM   #7
Lots of good ideas, thanks all for the comments.
FS amp cases woody Swap Meet 4 22nd April 2008 12:05 PM
Amp Cases x. onasis Swap Meet 8 23rd September 2004 07:05 PM
where to look for cases roofingboom Solid State 6 31st May 2004 03:57 PM
GC cases x. onasis Chip Amps 13 19th March 2004 10:05 PM
Page generated in 0.08573 seconds (75.24% PHP - 24.76% MySQL) with 10 queries
