Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 15th April 2008, 11:52 PM   #1
wendell is offline wendell  United States
Default low esr caps.......
What to look for in a low esr caps? i'm looking at panasonic fc from digikey , what do the following mean and how do they determine how the caps performance? I know that there are probably other caps out there like blckgates and rubycons but are pricier.
I have 3 project going on at the moment and I'm not looking to break the bank with the components unless i really need to,
1 leakage current,
2 Impendence
3 ripple current
do I look for high or low numbers for each one?
Old 16th April 2008, 12:27 AM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Default Re: low esr caps.......
1 leakage current,
2 Impendence
3 ripple current
1. low
2. low
3. high
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 16th April 2008, 11:05 AM   #3
Mooly's Avatar
Hi, Caps designed for switch mode PSU usually low impedance. This is linked to a low E.S.R. or equivalent series resistance. These are well suited for use where the ripple component is of high frequency. These often have 105 degree temperature rating as well. Leakage current is not an issue with any modern electrolytic. Ripple current is the amount of allowable current the capacitor can pass without overheating and is usually measured at 100hz or so. High ripple current is important for main smoothing caps in high current powersupplies. All electroylitics exhibit a rise in inductance with increasing frequency and this limits their effectiveness anyway, it is beneficial to add a small 0.1mfd cap across cap to counter this.
Regards Karl
Old 22nd April 2008, 12:01 PM   #4
housing is offline housing  Hong Kong
low esr caps have no bearing with the sonic of an audio device.
Old 27th April 2008, 04:19 PM   #5
does low impedance have an influence on sound?
Old 27th April 2008, 05:05 PM   #6
Mooly's Avatar
There's no yes or no answer to that one The low ESR cap is better able to decouple at HF. If it helps reduce noise on a rail that is beneficial, but it does not neccesarily mean the improvement is audible. Each and every capacitor has to be chosen according to it's function. Low ESR caps for example often have lower ripple current ratings at mains frequency (50/60hz) so are less well suited to some linear power supply applications. If you want a decoupling cap for a SMPSU running at 100khz you would be looking at a low ESR type, possibly with further bypassing with a small 0.1 or similar. There's no one size fits all.
Regards Karl
Old 27th April 2008, 09:00 PM   #7
Geek's Avatar
This is for an output cap to the speakers, right? Panasonic has great caps. There's a thread by P-A here that proves that.
The Digikey catalog shows the ripple handling current at various frequencies. What I would do is look for the one with the highest ripple handling current at 60 or 120Hz and get that. Then bridge the terminals with a 1 or 2.2uF polyester cap in the circuit.
And IMO, after repeated testing in this area, a generic Rubycon will smoke a Blackgate - the only thing the Blackgate smokes is your wallet
Cheers!
Old 27th April 2008, 09:29 PM   #8
FC and FM are the good lines from Panasonic for medium-sized capacitances at medium voltages. FK is also very good but is SMT. All are low ESR.
Low ESR electrolytics will provide good bypassing up until about 1MHz. Above 1MHz you need to use film or ceramics.
Old 28th April 2008, 08:41 AM   #9
ah, all too complicated for me.
btw, where can i get rubycon's from online? i compared the ZLH with the pana FM and in terms of low imp and ripple, the FM is ahead.
Old 28th April 2008, 02:05 PM   #10
Farnell for both
bypass caps for bypassing mylar caps? crippledchicken Multi-Way 4 27th February 2008 04:24 AM
Replacing multi-section caps with multiple caps? Sir Trefor Tubes / Valves 1 29th May 2007 10:17 PM
Silver Mica caps VS Polystyrene caps KevinLee Parts 24 17th September 2003 03:01 PM
Replacing ceramic disc caps with silver mica caps? G Solid State 5 18th November 2002 01:02 PM
FILM Caps to assist Big ELYT Caps gromanswe Parts 0 9th July 2002 08:16 AM
Page generated in 0.10108 seconds (81.06% PHP - 18.94% MySQL) with 10 queries
