| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
A relatively simple way to generate any waveform is by using a microcontroller, a look-up table or algorithm and a DAC. For a 90S8515 + absolute minimum of external components the code is really simple. You can easily get around 0.01% thd. Not to mention a whole new hobby
I am sure there are more elegant DSP based solutions as well.regards peter |
#12 | |
Electrons are yellow and more is better!
Don't expect better than 2%, maybe 1%. The sinus wave is triangle wave which is fixed in a unlinear circuit.
/Per-Anders (my first name) or P-A as my friends call me |
#13 |
Check out the oscillators described in these two aplication notes.
http://www.linear.com/pdf/lt1122.pdf http://www.linear.com/pdf/lt1115fa.pdf |
#14 | |
do a google search under "Walsh Series" for the mathematics. Don Lancaster also has an article on this at www.tinaja.com
| Nice Heathkit IG-5218 Low Distortion Audio Sine/Square Generator | dozer | Swap Meet | 2 | 12th January 2009 02:50 AM |
| Sine Wave Generator with bulbs (Sine-lightenment) | Rodeodave | Everything Else | 6 | 21st July 2008 01:19 PM |
| Sine wave - Square & Triangle wave generator using Transistors / OP-Amps | lineup | Solid State | 20 | 9th October 2006 01:15 AM |
| Page generated in 0.09265 seconds (70.96% PHP - 29.04% MySQL) with 10 queries |
