Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 5th March 2003, 01:36 AM   #1
Send a message via AIM to Mattyo5
Unhappy bc546, 556, bd139 sources/replacement help
I am building Anthony Holton's 400 watt symmetrical amp and it calls for bc546 556 and bd139 (I guess these are the small transistors). Digikey doesn't have them. Does digikey have anything that would be a drop in replacement? I found some stuff at Mouser, but I'm not sure its its correct, bc546B bc556, and BD139 ships in 14 days. I'd rather use digikey. Any ideas?
-Matthew K. Olson
Old 5th March 2003, 02:07 AM   #2
ashok's Avatar
Default Transistors.
" I found some stuff at Mouser, but I'm not sure its its correct, bc546B bc556, and BD139 "
If what you have found is what you typed above , it seems right. All those transistors are widely used. BC series have an A or a B or a C depending on the current gain. No letter is the least gain. In most cases any type would do except when high gain is a must by design.
BD139 is a higher power device (than BC5xx series) in a TO126 case I think.
You can go ahead and buy these from Mouser. I do not think you can go wrong.
Cheers.
AM
Old 5th March 2003, 02:10 AM   #3
Ok, well, I was trying to stick w/ digikey. Oh well. I'll grab em from mouser I guess. Anyone know of direct replacements from digikey? Thanks!
-Matthew K. Olson
Old 6th March 2003, 05:38 PM   #4
dwjj's Avatar
You might read this thread
replacements
digikey has 2sc4793/2sa1837 for bd139/140 and 2n3904/3906 might work for bc546/556. mpsa06/56 for bc546/556 has also been used. There are lots of threads with other options.
I don't think digikey has the following (just for more options). I also use partsexpress.com matelectronics.com and i-mcm.com to get transistors.
ESP http://www.sound.westhost.com/ uses MJE340/350 to replace BD139/140.
I've also gotten MPS8099/MPS8599 and MPS8098/MPS8598 from ebay that seem to work in place of BC546/556
It's cheaper than a movie, and there's free coffee.
Old 6th March 2003, 09:04 PM   #5
Thanks. I got the extra stuff from Newark instead. Don't know why. Just did. I tried partsexpress (who is my favorite actually) but they only seemed to ahve the MJE340/350's...so I got those from them. Newark was fine too though.
Thanks for posting though, now i have a reference in case I need it.
-Matthew K. Olson
Sources for Replacement Fender Filter Caps jl_lensman Tubes / Valves 3 13th May 2009 02:30 PM
which is the echivalent of BC546 in SMD? nbcd Parts 1 30th April 2003 05:15 PM
P3A amp - BC546 Placement dine1967 Solid State 9 3rd January 2003 01:39 PM
BC546 A or B in P3A DaViruz Solid State 4 23rd November 2002 12:16 AM
Page generated in 0.08701 seconds (75.53% PHP - 24.47% MySQL) with 10 queries
