Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th March 2008, 09:17 PM   #1
Default What is this cap called?
What is this capacitor called, what size is it? And where can I get one? I just received a MTX amp to fix and it looks like the only issue is this cap, but I have never had to run across these before until now.
I am going to try to attach the picture.
Old 19th March 2008, 03:09 AM   #2
Geek's Avatar
That's a surface mount electrolytic I believe. Almost everyone has those, Digikey, Newark, Mouser, etc...
100uF @ 25V if I read that right.
Cheers!
Old 19th March 2008, 12:12 PM   #3
Great, thank you!
Old 19th March 2008, 05:42 PM   #4
Now I found another bad one. 10 KFK 5K2 Would that be a 10 uF cap?
Old 20th March 2008, 12:34 AM   #5
Geek's Avatar
Yup!
How are they bad? I know one's used in PC's are horrible little pieces of junk, but never heard of so many bad ones in an audio unit
Cheers!
Old 20th March 2008, 03:27 AM   #6
They broke off the circuit board, I opened the case and 1 fell out, then after replacing that one I searched around for anymore loose ones and another one just fell off the board when I poked it, so I replaced them both with regular style caps as thats all I have on hand, now it's time to diagnose the big problem. Thanks for your help!
Old 20th March 2008, 05:34 AM   #7
Geek's Avatar
No problem!
Junk solder joints are the bane of many an otherwise decent design
Cheers!
what is this called skullkeeper Parts 1 23rd April 2009 11:28 PM
What is this Amp design called? packer Solid State 2 1st March 2009 12:11 AM
What is this topology called? teemuk Solid State 7 27th July 2007 09:52 AM
What's it called? Cal Weldon Multi-Way 10 16th June 2007 05:29 PM
What is this connector called? megajocke Parts 10 7th February 2007 06:10 PM
Page generated in 0.08771 seconds (71.25% PHP - 28.75% MySQL) with 11 queries
