Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th March 2003, 02:35 PM   #1
Default Sources for transistors in the UK
I trying to build a Theremin, from Popular electronics plans, circa 1967. The circuit calls for the following semi conductors:
Motorola MPS3638 Transistor
Motorola MPS3708 Transistor
Texas Instruments TIS-59 N-Channel FET
I cannot find these in Farnell's, RS Components or Maplin. Are they still available generally, and if so, where shoul I look? Alternatively are there any equivalent replacement products that ay be easier to get hold of?
Kind regards,
Edward
Old 4th March 2003, 08:28 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Hi, mcai7et2
These transistors are as old as the amp you are trying to build.
I can give you substitutes but I don't know the amp, so no guarantee they will perform.
It could be interesting to post a schematic. More experienced
people will be able to give you better advice then.
Here you go:
MPS3638= 2N3638: NF/S, 25V, 0,5A, 0,3W, <90/170ns
MPS3708= 2N3708: NF, 30V, 0,03A, 0,36W, 80MHz,B=45..660
TIS59: BF 244..245
2N3638:BFX40
2N3708: BC550C
All 3 available at Farnell.
/Hugo - Has the feeling that this amp must be very special...
Old 5th March 2003, 12:01 AM   #3
colin.hepburn2's Avatar
Hi Edward
Sorry Cana Help with you trans But would like to now where you get you’re parts form in Aberdeen as I am just about 10 miles south of you at newtonhill
Cannot rate maplin these days I think I has got down hill for parts now
Do you know where to go in Aberdeen for aluminum for case work and big? Heatsinks for Class a Amp
You mite want to try this link for the trans
http://www.rapidelectonics.co.uk
Colin
Colin
The Blues Man
Old 5th March 2003, 01:02 PM   #4
Default Actually...
Its not an amp at all, a Theremin is a musical instrument that is controlled by moving your hands in the vicinity of two aerials, one controlling pitch and one volume.
Circuit diagram is here:
http://www.maxiespages.com/theremin/...schematics.pdf
Thanks a lot for the information, I will try those and let you know how I get on.
Regarding electronics suppliers in Aberdeen, RS Components have just opened a trade counter in Altens which is a relief, because as you mentioned, Maplins in Aberdeen suck.
Ed
Old 5th March 2003, 01:23 PM   #5
Netlist's Avatar
Default Re: Actually...
Ed
Looks very interesting. Keep us informed about the progress.
/Hugo - thinks only amps carry transistors
List of Sources hams Parts 1 17th June 2004 01:18 AM
MJ15003 Sources ultrachrome Solid State 5 5th March 2003 06:16 AM
Elliott P3A US Transistors, Sources and Prices aborza Solid State 4 19th November 2002 09:15 PM
Sources of hum. JoeBob Solid State 30 19th July 2002 04:23 PM
Page generated in 0.10283 seconds (69.68% PHP - 30.32% MySQL) with 10 queries
