Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
How to separate E from I in transformer?
Old 4th March 2003, 12:21 AM   #11
dkemppai is offline dkemppai  United States
Just soak the thing in a big container of acetone. I do it all the time with switching power supply transformers. Takes some time for the varnish to soften up, and you can't use the wire again, but it works well.
-Dan
Old 4th March 2003, 12:50 AM   #12
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
Default Nail polish remover even.
Excellent! Is paint thinners suitable or only straight acetone? I have two trannies that have been submerged in gasoline for a little over 2 weeks now. Do you think that would work much?
Old 5th March 2003, 12:04 AM   #13
Default Re: Nail polish remover even.
Dunno about gas... ...gotta pick your solvent for your purpose. The acetone will soften the surface varnish immediatley... ...it'll be tacky as soon as you get it wet. Do the same check with the gas. It takes time to soak into the little cracks and crevices.
Nail polish remover used to be acetone, but I think the stuff used now is a non-acetone chemical. (Wife just verified some of it is not acetone) You can buy actone in most painting supply stores... ...I even buy it at wal-mart. It's not really all that expensive.
I just store the transformers in the acetone until I'm ready to unwind them. It also helps to use a pair of chemical resistant gloves when unwinding the transformer... ...as soon as the acteone dries, the varnish seems to set up again Gets all over your fingers otherwise...
-Dan
(Foget the pic, I can't get it to post!!!!)
Old 5th March 2003, 12:26 AM   #14
apassgear is offline apassgear  Mexico
apassgear's Avatar
When new EI lamination has a thin oxide layer left by the oil used during stamping (cutting) with the die. This oxide forms after they heat the cut laminations in an oven.
In my experiance the best way to undoo a transformer is by heating it to burn all but the metal. Heating lamination wont degrade it, in the contrary it may betterd it and you will still have an oxide layer. It wont act a a solid chunk of iron.
When putting back the transformer you must varnish it again, with thin electrical varnish this will penetrate beteen the lamination. After this proccess you will find the efficiency of the trany will be better than before (to various degrees).
What degrades lamination is the mechanical work over it like hammering or tweesting.
Never tested using solvent to undoo a trany so can't comment.
Old 5th March 2003, 12:33 AM   #15
apassgear's Avatar
After burning a transformer don't cool it on water it's best to let it cool as slow as possible.
Old 1st November 2006, 08:20 PM   #16
sorenj07 is offline sorenj07  Germany
sorenj07's Avatar
OK, cool. Into the bath of acetone goes my little wall-wart transformer
How to separate E from I in transformer?Hide this!Advertise here!
Separate PSU grounding decky Power Supplies 1 20th March 2008 08:40 PM
Separate chambers pei Multi-Way 2 7th January 2007 04:02 PM
Separate Pre-amp or Inbuild debipilu Solid State 3 4th January 2003 08:13 AM
Copyright ©1999-2017 diyAudio
