Can someone identify this component? Can someone identify this component? - diyAudio
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 27th February 2008, 04:54 PM   #1
teemuk is offline teemuk  Finland
Default Can someone identify this component?
I was cannibalizing this old integrated tuner-amplifier when I came across this mysterious component (see attachment). I don’t have a photo but one would not likely be any help either since there were no type markings of any kind. Here’s a verbal description, though: The component has three pins and two of them are closer to each other like depicted in the (quickly drawn) picture. One pin connects to the ground reference, one pin connects to audio output of the tuner circuit board and one pin connects to audio output of FM stereo demodulator chip (MC1309P) through a coupling capacitor. There were two of these components, one for each channel. The component has a plastic casing (without type markings) and the plastic case was covered by a metal “cage” that was bent from thin sheet metal. Its size is that of an ordinary relay – and relay was in fact the first thing I thought the component was. However, considering the pinout and the circuit configuration that doesn't make any sense.
I am completely puzzled by this - could it be somekind of an auto-transformer?
Old 27th February 2008, 05:17 PM   #2
poynton is offline poynton  United Kingdom
poynton's Avatar
Default Re: Can someone identify this component?
Band-pass filter
Old 27th February 2008, 05:58 PM   #3
Now why didn’t I think of that?
Makes sense. Thanks Poynton.
Old 27th February 2008, 06:25 PM   #4
head_spaz is offline head_spaz  United States
It sounds like you're describing a "SAW Device."
A SAW device is basically a capacitive piezo driver mounted on a substrate with a piezo receiver on the other end. It only couples signals in a fairly narrow band from transmitter to receiver. As I recall, the substrate is actually resonating (standing waves). They make awesome filters.
Sometimes they're called SAW Resonators, but are more commonly referred to as SAW Filters.
Writing is good exercize for the texticles!
Old 28th February 2008, 09:23 AM   #5
Elvee is offline Elvee  Belgium
Elvee's Avatar
Default Re: Re: Can someone identify this component?
Originally posted by poynton
Band-pass filter
More accurately, probably a combination of low-pass filter and notch filter(s). (At 19 and 38KHz).
Old 29th February 2008, 03:09 AM   #6
Petraman7 is offline Petraman7  United States
Send a message via Yahoo to Petraman7
A SAW filter wont output an audio signal. It's most likely a filter. Input and output have a common ground
Old 29th February 2008, 12:54 PM   #7
lcsaszar is offline lcsaszar  Hungary
Default Re: Re: Re: Can someone identify this component?
They used it back when tape recordes were more common than nowadays. The bias oscillator created a very annoying audible beat with the 19/38 kHz, the filter was there to prevent this.
Can someone identify this component?Hide this!Advertise here!
Can you identify this cap? Richidoo Parts 4 13th March 2009 11:53 PM
Help Identify this component! DoomPixie Parts 10 28th August 2006 03:01 PM
Help me identify this Surface mount component jives11 Parts 6 8th December 2005 02:50 PM
Please help me identify this Lloyd1986 Subwoofers 5 26th January 2005 09:48 PM
Help to identify component aeon845 Parts 1 19th May 2004 04:35 PM
Copyright ©1999-2017 diyAudio
