Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 1st March 2003, 10:32 AM   #1
Ralph is offline Ralph  Netherlands
Ralph's Avatar
Default Question about 555 timer circuit with relays
I found a nice delaying circuit to switch on the B+ circuit of my PSU. It's just what I need:
http://www.ultranalog.com/schem/hvdelay.pdf
I have 4 circuits I want to switch on, all 5V/2A for the 4 rectifier tubes: http://www.homepages.hetnet.nl/~rjonkers/psu.gif
I'm planning to use 4 of these 12V relays http://www.farnell.com/datasheets/7611.pdf that consume 360mW each
* Now my question, can I switch all 4 relays with just a single 555 circuit, or do I need to build 4 circuits like the one above?
* Is it ok to use 13.7v at the input of the circuit (then I will have 12v for the relay as the 555 drops 1.7v)?
Thanks, Ralph
Old 1st March 2003, 10:45 AM   #2
Send a message via MSN to blank527
For your questions
1 - No I wouldn't do that, because you source the output to much and the 555 will break.
I should put 4 BC560 in parallel and with higher input ressistor (not much)
2- The 555 has a large range of operating voltages, but I would put some stabillity around this IC.. beceause it could affect the output. some elco's close to the IC power should do this job.
Last.. read the datasheet for timing, when the relays comes up.
Grtz,
Remco Blankesteijn
Old 1st March 2003, 11:02 AM   #3
Electrons are yellow and more is better!
peranders's Avatar
I don't agree with Mr. Blank.
First of all: You must get the datasheet of the same brand as the one you have. LM555 isn't exactly the same if we talk ON, National etc. certainly not the CMOS type.
If we take National:
16 volt max as supply voltage and absolute max is 18 V.
Max current is 200 mA, your load is 120 mA.
The only thing you have to think about is to add a diode 1N4001-7 across the relay coils, cathode towards +.
Let me also add, it isn't wrong to be a little bit cautious, a separate transistor doesn't hurt.
/Per-Anders (my first name) or P-A as my friends call me
Tube Buffered Gainclone in work |Thread
Old 1st March 2003, 11:09 AM   #4
Ralph's Avatar
The IC will be a PHILIPS SEMICONDUCTORS, Manufacturer Part Number NE555N. Maybe I should look for a relay that consumes a little less power.
Old 1st March 2003, 11:19 AM   #5
Keld is offline Keld  Sweden
Keld's Avatar
Default Re: Question about 555 timer circuit with relays
Originally posted by Ralph
SNIP
SNIP
Thanks, Ralph
Or you can let one (smal) relay operate the other 4.
Keld
Old 1st March 2003, 11:21 AM   #6
peranders's Avatar
If Philips also can deliver 200 mA I see no reason why you can use a 120 mA load (4 x 0.36/12).
Old 1st March 2003, 01:39 PM   #7
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Ralph,
Why so many relays?
Surely you just need 1 x 2-pole relay per monoblock.
It is only necessary to interrupt 1 heater connection on each rectifier
Old 1st March 2003, 02:42 PM   #8
Ralph's Avatar
Hi John
I selected two 2-pole relays from Farnell:
959-455 DPCO, 10A - 44.62 Series
http://www.farnell.com/datasheets/4039.pdf
and
431-382 DPCO, 8A - 40.52 Series
http://www.farnell.com/datasheets/396.pdf
both are rated as 55mA consumption (so 110 together, which is way within the 200mA 555 specs). Will they both be ok?
Old 1st March 2003, 04:53 PM   #9
dhaen's Avatar
Ralph,
I think the relays willl be OK. But why 2?
PS Don't forget to add a reverse biased diode across the coil.
Old 1st March 2003, 05:48 PM   #10
Ralph's Avatar
Well, the 300B circuit has 2 rectifiers (L+R) and so has the 5687 circuit. That makes 4 high voltage circuits and therefor I need two 2-pole relays.
And I won't forget the diode, it's in the schema I'll build (D1) http://www.ultranalog.com/schem/hvdelay.pdf
Do I need a Timer Circuit? silentblackhat Digital Line Level 4 1st February 2009 09:16 PM
Soft-start circuit with no relays and no aux. transformers Eva Power Supplies 72 23rd March 2007 08:30 AM
quick question about tube relays Scott_fx Tubes / Valves 10 19th October 2006 07:32 PM
Question about automotive relays?? jaygeorge1979 Car Audio 4 21st April 2006 02:23 AM
Copyright ©1999-2013 diyAudio
