How long will 9V batteries last for powering opamps? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 28th February 2003, 12:53 PM   #1
Account Disabled
Default How long will 9V batteries last for powering opamps?
I will be using BB opamps for some filtering (bass boost, and a subwoofer XO). I am considering powering them with two 9V batteries. How long will these last? I assume it is really really long, but if it is only several hours I will just make my own PS.
-Paul
Old 28th February 2003, 01:40 PM   #2
jackinnj's Avatar
Default not long with a NE5532
but there are a lot of micropower rail to rail single supply opamps out there from all the usual suspects. Use the parametric search engines to find a very low power or micropower opamp.
Old 28th February 2003, 03:02 PM   #3
Electrons are yellow and more is better!
peranders's Avatar
Normally it's rather expensive to use batteries for HIGH fidelity. 9 V battery has 100-170 mAh or more which gives operation of a couple of hours up to a day or two.
Take the capacity (mAh) and divide this with the current consumption 1-10 mA.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 28th February 2003, 03:55 PM   #4
Won is offline Won
Default Lithium 9V Battery
Energizer makes Lithium based 9V cells that have quite a bit more juice packed into them. They have several other advantages, too, but probably not significant for a fixed, home environment. They are also lighter, so they would be better for portable use, less sensitive to temperature, flatter output over time, etc.
Of course, they are like $7 per battery, so they are alot more expensive.
-Won
Old 28th February 2003, 04:05 PM   #5
peranders's Avatar
If the person isn't very rich there are two choices:
Very low current consumption = long operation time, not so expensive
Use rechargeable batteries = cost some in the beginning then it's for free (almost).
FS: Power Chip OpAmps and other OpAmps & D to A Converter dtm1962 Swap Meet 4 12th January 2006 10:07 PM
are batteries a long term solution??? MegaMe Class D 1 15th November 2005 12:16 PM
Powering speakers over long distances? edave Everything Else 5 2nd April 2005 10:06 AM
Powering LM3886 with 12V Batteries VoLCoM Chip Amps 9 15th March 2004 01:38 AM
Forgot to do this long long time ago chris ma Introductions 2 30th October 2003 10:53 PM
Copyright ©1999-2017 diyAudio
