Non-Polar Electrolytic vs. Polypropylene Film Capacitors Non-Polar Electrolytic vs. Polypropylene Film Capacitors - Page 2 - diyAudio
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 19th February 2008, 03:51 PM   #11
On Hiatus
SY's Avatar
Fixed the typo.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 22nd February 2008, 01:58 AM   #12
Conrad Hoffman is offline Conrad Hoffman  United States
David, yes you can measure the voltage coefficient, and the various types are definitely different, with some ceramics being pretty easy to see. This is one reason I like my antique bridges, as they can go up to several hundred volts, unlike modern solid state bridges that are doing well to get to a couple tens of volts.
You should also measure dielectric absorption. It's sort of a PITA, with accurate timing required. I bought a computer interface with this exact thing in mind, but haven't had time to set up the experiment.
Conrad
Old 22nd February 2008, 02:11 AM   #13
roddyama is offline roddyama  United States
diyAudio Moderator Emeritus
roddyama's Avatar
Here is a link to a reprint from Audio magazine by Walt Jung and Richard Marsh called "Picking Capacitors"
Rodd Yamashita
Old 22nd February 2008, 02:16 AM   #14
poobah is offline poobah  United States
poobah's Avatar
Conrad,
Your dielectric studies shifted into water absorbtion instead of charge didn't they?
How all that mess goin' anyway?
Old 22nd February 2008, 02:20 AM   #15
cocolino is offline cocolino  Germany
cocolino's Avatar
In this article by Bob Pease are described two test fixtures to measure DA:
Understand Capacitor Soakage
A simple one with a switch which has to be engaged manually and more a much more sophisticated with timers etc.
Christoph
STEAL the BEST - INVENT the REST
Old 22nd February 2008, 02:30 AM   #16
poobah, the carpet is long gone, the walls are torn out, everything is a mess, but I cleaned the seaweed and dead fish off the test bench, replaced the power strips that were under water, and at least I'm up and running! Fortunately I didn't lose much, though I did spend some time washing the components that were in the lower drawers of my parts cabinets. I also discovered you can recover some amazing things, if you act quickly. I opened up a nice dial indicator that was completely submerged, cleaned and relubed it, and it works better than new. I also have some mylar caps that were under water for a week, so I ought to check the DA on 'em! No, wait, this is 2008- just call them minty and sell them on eBay!
Old 22nd February 2008, 02:37 AM   #17
dave_gerecke is offline dave_gerecke  United States
Thank you to all of you who provided data from personal research and those who provided links to articles and equipment.
Conrad, what is your ebay ID, I need to watch for those caps!
Old 22nd February 2008, 03:02 AM   #18
Iain McNeill is offline Iain McNeill  United Kingdom
Iain McNeill's Avatar
Thank-you and kudos on presenting some real data. Your efforts are to be applauded. As we all know, from data comes knowledge, from knowledge, wisdom.
The esr of capacitors isn't so critical because their reactance is so high at low frequency. For instance 3.3uF at 100Hz has a reactance of 482 ohms so an ohm of ESR doesn't really make much difference. Even at 10KHz, the reactance is 4.8ohms. Not to say it's not important, it needs to be taken in context and of course, it's the opposite for inductors, ESR is the essence of inductance.
As far as I know, bipolar electrolytics are formed by making a pair of double value electrolytics in series and so you'd expect their ESR and DF to be 2X worse than regular electrolytics. Let's face it electrolytics were created to do one thing well, dump lots of low frequency energy. They are not intended for audio duty.
When you give a value of <0.1ohm for instance, what do you mean? Is 0.1ohm the limit of measurement for that test condition?
I vote to make this a sticky that we should all put our data. I, for one, would really like to know if a particular manufacturer knows what they're doing!
Old 22nd February 2008, 03:06 AM   #19
BTW, I always thought that the reason electrolytics varied capacitance so much with frequency was due to the parasitic inductance of their construction (a coil of foil). Can anyone elucidate?
Old 22nd February 2008, 03:30 AM   #20
Boris_The_Blade is offline Boris_The_Blade  United States
Boris_The_Blade's Avatar
An excellent electrolytic capacitor read: http://electrochem.cwru.edu/ed/encyc...electr-cap.htm
frequency response is claimed to be roll off due to "roughness of the surface oxide," whatever that means
Non-Polar Electrolytic vs. Polypropylene Film CapacitorsHide this!Advertise here!
PSU capacitors: 30uF film ok instead of 100uF electrolytic? sharpi31 Parts 3 13th September 2008 08:49 AM
Polypropylene vs electrolytic in Power supply duderduderini Tubes / Valves 25 27th September 2007 02:43 PM
Is plastic film capacitor same as polypropylene ? goldyrathore Solid State 43 8th March 2004 09:16 AM
Dayton Metallized Polypropylene Film and Foil Capacitors? rdunnit Parts 4 29th July 2003 07:02 PM
Can I make a Non-Polar Electrolytic using two polar ones PaulHilgeman Parts 6 10th February 2003 12:07 AM
Copyright ©1999-2017 diyAudio
