Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
toggle switch for input selector
Old 14th February 2008, 04:06 AM   #1
audio_moksha is offline audio_moksha  India
Default toggle switch for input selector
Is it a good idea to use a 4PDT toggle switch to switch between two inputs? I have two inputs on my integrated EL34 SE and I wanted to use a toggle switch for aesthetic reasons but I've heard that it could be noisy. The 4PDT toggle switch I have has a 10 milli ohm contact resistance @2-4V. I just want to make sure it will work before I mindlessly drill a hole into my beautiful chassis.
On the other hand, how do I implement 3 or 4 inputs or in other words what kind of rotary switch do I need for it? I've never done more than pair of RCA input until now...
Old 14th February 2008, 04:18 AM   #2
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
I used a DACT in my switchbox (3 turntables -> 1 phonostage)
Old 14th February 2008, 04:30 AM   #3
HollowState is offline HollowState  United States
HollowState's Avatar
To avoid pops and other noise when switching, I like to use make-before-break rotary switches. These are also known as shorting rotary switches. Toggles are only non-shorting as far as I know. One could even go so far as to use extra sections on a rotary to short out any selection that is not in use. Some say this helps reduce crosstalk, although I've not found that to be much of a problem. You probably don't need to switch the ground side, only the hot side. Small DIP relays are another idea.
Victor
There cannot, and never will be, any progress in society, vis-a-vis racism, so long as the concept of celebrating Diversity -- in it's current, politically-correct, deliberate, punitively extractive form -- continues.
Old 14th February 2008, 04:30 AM   #4
syntheticwave is offline syntheticwave  Germany
Send a message via ICQ to syntheticwave
If it this switch,
http://www.web-tronics.com/general-s...ches-4pdt.html
it should be a good choice to switch between two stereo RCA inputs.
Old 14th February 2008, 07:59 AM   #5
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
I've used toggle switches as I happened to have such at hand (but no rotary), and have had no problem.
However if you want to be fanatic, make an assy with some relays and some logic, controlled by the toggle switch, that shorts the inputs while switching.
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 14th February 2008, 12:47 PM   #6
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
If you use a toggle switch, get one with gold (or gold over silver) contacts - best for low-level switching.
Old 14th February 2008, 02:20 PM   #7
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
toggle switch for input selector Send a message via AIM to Peter Daniel
I use toggle switches in my integrated amp and they work great: http://www.diyaudio.com/forums/showt...55#post1069555
The TOCOS Toggle Switches have superior quality silver contacts and can be sourced from Percy Audio.
To order kits contact me through forum mail.
Old 14th February 2008, 02:30 PM   #8
hermanv is offline hermanv  United States
There are toggle switches made for high power or electric motors, for a full size switch these will say 10 Amps or maybe 1/2 HP. These types typically have Cadmium contacts and will become noisy. Purists will not like anything other than silver or maybe gold contacts.
Spend a few dollars, buy the right switch (such as from Percy) especially if you're going to drill holes in a nice front panel.
Old 14th February 2008, 07:05 PM   #9
Thanks for all the input guys; I just might end up getting the DACT selector
Old 12th November 2008, 01:27 AM   #10
garak is offline garak  United States
Sorry to resurrect an old thread, but I have a legitimate question.
Why are gold and silver contacts considered superior in switches? Isn't copper a better conductor than either? Is it really likely to corrode very much when encased inside the switch housing, in a typical home environment? That's the only reason for silver and gold right? Corrosion resistance?
toggle switch for input selectorHide this!Advertise here!
Best sounding analog switch IC for input source selector rythmikaudio Solid State 14 20th November 2016 03:03 PM
Fotios need help with input selector. Rotary switch or Relays? fotios Solid State 49 26th December 2010 12:31 PM
Phono input selector switch Woodsong Audio Analogue Source 21 6th March 2010 04:19 PM
simple 2 input selector switch for audio amp gychang Parts 6 12th March 2008 03:49 AM
Noise when using input selector switch Nuuk Solid State 12 5th July 2006 04:11 PM
